Results 1 to 7 of 7
Thread: If im having the pc in the boot, how do i get the cables to the dvd drive in the dash
    Apr 2005
    The ide cable and molex will need to be at least 8 feet long, how is this possible?
    Or would it be better to put the pc under a chair?
    Although the cable still needs to be 4 feet long?
    HELP PLEASE
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Use a IDE -> USB converter and then run a 8 foot usb cable from the back to the drive. For the molex connector use 4 strands of 18 gauge wire to run the power to the drive.
    edit: something like this.
    http://cgi.ebay.com/ws/eBayISAPI.dll...765747245&rd=1
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Apr 2005
    Whats the power supply for?
    Dec 2003
    New York
    Thats if your using the drive in your house. Then you would give the power to the drive from the power supply. You really don't need it in the car unless your using an inverter then you could use the power supply instead of running the 8 feet of wire for the molex connector.
    Installed
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    There's several people using lengthy IDE cables. Do a search on "IDE cables" or "IDE length" or variations. You'll find posts on running lengthy IDE cables.
    Want to:
    Oct 2004
    South Carolina
    i also recommend getting a IDE to USB adapter. is it a slim drive? then you will need to find one for that. and then just run power from your power supply
    Feb 2005
    Make your own IDE cables...it's quite easy.
  1. usb dvd drive
    By skydiver in forum Hardware Development
    Last Post: 02-10-2005, 10:08 AM
  2. DVD drive missing from hibernation
    By R32 JUhl in forum General Hardware Discussion
    Last Post: 02-08-2005, 04:57 PM
  3. slim dvd and 2.5" hard drive cables
    By warnockm in forum General Hardware Discussion
    Last Post: 01-03-2005, 06:08 PM
  4. Using DVD drive
    By oekundar in forum General Hardware Discussion
    Last Post: 12-06-2004, 07:01 PM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
