Results 1 to 10 of 10
Thread: USB OEM Look?
    Newbie rdcravens's Avatar
    Mar 2005
    Chicago (area), IL
    USB OEM Look?
    I have a 93 BMW 325i with some unused switch areas under the cubby (next to the cig lighter). I am planning on putting a remote on/off switch there for my PC... However I have 3 more slots I can fill (all are about the size of the top of a cigarette pack).
    What I am wanting to do is add usb ports to the areas, however make them look OEM... (I like to use memory sticks, and I plan on having a mini usb keyboard)
    Has anyone ever done this before? Is there any equipment on the market that I could take apart and create a cut out and have the USB connector slide right down in (and then run to my trunk where the pc is)? I hope I am explaining this well enough to give you a visual... Maybe, if needed, I could take a pic and draw something up...
    Thanks!!
    Rodger
    Rodger
    Chicago (area), IL
    ** MCS Car PC - Win XP - Running G-Net Digital Dash - GPS - Real Time Vehicle Diags
    ** PIONEER DEH-P6900UB - Pioneer Sirius Stuff -Ipod Integration
    ** Seperate DVD player (less usage of Car PC)
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    hmm... how about "send some pics"
    Mar 2005
    Just get creative with a USB hub and some decent fabrication. I've seen stock looking USB ports. If you want it to look really OEM, put a cover over them.
    Dave
    Apr 2005
    Kaneohe, HI
    I agree with Dave (and Laguna), go for a USB hub device flush mounted. Though pictures would be helpful for us poor folk who don't know what a BMW interior looks like. Like they say, worth a thousand words...
    Mar 2005
    Chicago (area), IL
    Here are some pics of the interior... The section I am talking about is just in front of the shifter...
    Rodger
    Chicago (area), IL
    Newbie ysutarko's Avatar
    Mar 2005
    Artesia, CA
    i only have 1 usb port to charge my Treo or play mp3 from my Cruzer micro
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    We would need pictures of up close to the shifter. Otherwise, we we really can't be sure of what you are talking about.
    But they're right. Just get a hub, get the ports off of it, and fabricate something to hold them in place. That's one of my next projects. You just gotta make it look good where you put it.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Mar 2005
    Chicago (area), IL
    Found what I was thinking about... Damn I wish I would have thought about it before... So simple, yet so hard... lol..
    Here is what I got..
    The 3rd pic is the only thing I must overcome... I have never spliced a USB cable before and am not sure how much resistance the splice (solder) will cause... Anyone ever tried it?
    Rodger
    Chicago (area), IL
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    I don't know if it's been done before, but to run it much longer then it is now without shielding in the car might cause problems.
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    Bury the hub in the car.... run a USB extension to the switch plate.
    Cut the opening on the swithc plate to fit the usb.
    at least that's what I would think of....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  1. Replies: 15
    Last Post: 05-04-2006, 05:53 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  5. USB DVD + Radio Tuner + OEM GPS
    By gguy in forum General Hardware Discussion
    Last Post: 02-13-2001, 12:43 PM
