Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: USB DVD drive not reading dics
  1. #11
    Feb 2005
    Oklahoma
    well I have a molex pin remover and I have already hacked a Floppy plug off of an old power supply. I will just try soldering the plug first and testing with a multimeter. Thank sfor the Idea though.
  2. #12
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    I have split the red and the black from the molex connector running power to my lilliput up front, Can I simply splice into these lines and split them to the dvd player?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
  3. #13
    Feb 2005
    Oklahoma
    from what he said it seems it is possible.
  4. #14
    FLAC SFiorito's Avatar
    May 2004
    the lilliput needs 12V which is yellow. the USB device needs 5V which is red.
  5. #15
    Feb 2005
    Oklahoma
    I checked my plug and the drive is alrady on the 5V power line. If I would have swapped it with the 12V, it would be bye bye slimline dive. Any other options? I will have to test my Keypower PSU and see how far off the 5V rail is from true 5V. Maybe that is why it keeps shutting off.
  6. #16
    Feb 2005
    Oklahoma
    I am at a lose. I am sure someone else has had this issue before. I tried the Slimline drive on IDE with the slimline -> IDE adapter and the drives works fine, so power issue doesnt seem to be it. Tried a 12V CDROM drive on the USB adapter and that drive works fine. So all the individual components seem to be working fine.
  7. #17
    May 2007
    I have the same problem, I am running a 5metre extension direct from the pc to the dvd drive and measured the voltage entering the drive at 5v but the computer doesn't read the dvd, I have swapped it with a big dvd external drive which works fine but i would like to use the slim one any ideas
  8. #18
    May 2007
    another question is how do i reduce the cars 12v supply to 5v 2.0a for the drive as i have been using a plug in converter and I would like to hard wire it?
  9. #19
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I am having similar probs...I have a SLIM USB Pioneer DRV-K05.. To answer your power question you need to hook it up on the 5 rail of the PC...(Red wire in the molex connectors).
    I have mine powered via 5v rail. With the little 2 FT USB cable it runs fine!
    Add any more than that and windows cannot find! Kind of eliminates the purpous if you can't move it more than 2 feet away deson't it? It seems like data loss, because the power is sufficient. Any takers?
  1. USB hard drive and hibernation
    By Chairboy in forum General Hardware Discussion
    Last Post: 11-12-2004, 05:39 PM
  2. another USB slot dvd thread!
    By tdevil in forum Newbie
    Last Post: 08-21-2004, 01:17 PM
  3. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
  4. DVD drive problems... Anyone have any ideas?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-27-2004, 10:35 PM
  5. External USB drive
    By mtmsol in forum General Hardware Discussion
    Last Post: 11-27-2001, 06:25 AM
