Results 1 to 9 of 9
Thread: Carputer interfering with keyless entry
    Mar 2005
    I've noticed with the addition of my new carputer that my keyless lock doesn't work. Anyone else experience this? I assume it's either the GPS antenna or the XM radio antenna. Not sure if there is any way to solve this.
    Constant Bitrate csnowman00's Avatar
    Feb 2005
    Wilkes-Barre, PA
    what kind of car do u have?
    Current Progress:
    Final Assembly
    Ramline P3 PC
    10.4 inch Touchscreen
    Windows XP Embedded
    Road Runner
    Electrical Engineer / Mobile DJ
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by TimmyB1979
    You probably screw up the installation (cutting wrong wires.....)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Newbie lee03's Avatar
    Feb 2005
    i have tested it and when i have my carputer hooked up, the range on my keyless is reduced. When i remote start, and try to unlock with keyless, i have to stand within 5ft of the vehicle. ~sucks wish i could figure it out
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    i had the same problem with my keyless entry. 2001 crown victoria. My range is reduced also. If I unplug the xenarc from the cig plug, the range is increased. I wired my screen to a relay and wired the relay to the key. This solved my problem with keyless entry.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Constant Bitrate takissd's Avatar
    May 2004
    San Diego, CA
    i have an eclipse 2000 and i had the same problem. problem was i was using the power line (+12V) from the radio line ( probably the keyless entry cirquit was powered by this line??) when i changed my setup i used a separate line directly from the battery. After doing that keyless entry range is normal AND Xenarc is still on power save mode (which in my case means Xenarc is not decreasing keyless entry range)
    Try using a separate power line... if you are not doing so yet.. else i am not sure what it could be..
    -VIA EPIA M10000/512MB/40GB HD
    -DWW motorized 7'
    -BU 303 GPS w/iGuidance/ CF
    -Belkin Bluetooth
    -Pioneer HU
    [||||||||||] 95% done
    Constant Bitrate trance728's Avatar
    Mar 2005
    Huntington Beach, CA
    it could also be if you have anything running on an rf signal it could interfere with your remotes
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I don't have remote start but my factory alarm has that issue. The problem is intermittent in my case howeber. Everything is normal when carputer is off (Lilliput is served of the PSU so it comes on or off with the carputer) but sometimes when it is on, I either have no respons from my key fob or if I do it is for a very limitted range. I am guessing RF interference is causing it but don't know how to sheild it.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Newbie Brunation's Avatar
    Feb 2005
    Orlando FL
    Same issue here. My keyless entry works but the range was decreased to about 5 feet from the front of the vehicle. I'll disconnect the carputer to see what happens. At first I thought it was a low battery on the remote.
    "There aint no Nation like Brunation"
    Carputer Project: 80%
    VIA M10000 w/ 1gb Ram
    200gb 3.5 HD
    Opus 150w
    XP w/ Frodoplayer
    more to come...
  1. bluetooth keyless entry
    By blahgod in forum General Hardware Discussion
    Last Post: 02-17-2005, 10:09 AM
  2. keyless entry + remote start recommendation
    By cadence117 in forum General MP3Car Discussion
    Last Post: 12-20-2004, 08:12 PM
  3. EBAY: Rattler 100 Keyless Entry
    By binary.h4x in forum Classified Archive
    Last Post: 06-24-2004, 11:38 AM
  4. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 09:30 PM
  5. Using the Keyless Entry Remote
    By Sinorm in forum Input Devices
    Last Post: 04-07-2004, 07:34 PM
