Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 105
Thread: [REVIEW] In-Bumper Rear-view camera
  1. #61
    Newbie lossol's Avatar
    Jun 2005
    Virginia
    Has anyone had problems with this model fogging up? http://cgi.ebay.com/ws/eBayISAPI.dll...ory=32826&rd=1
    I have developed some moisture on the inside of the lens. Now everything looks foggy. BTW I wish it had a larger viewing area. Its mounted underneath the center of the rear bumper. It only has 53 degrees viewing angle.
  2. #62
    Raw Wave justintime's Avatar
    Apr 2005
    Looks like that is the same seller KAWAMALL, but only with sub $30 items. Weird.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #63
    May 2003
    Quote Originally Posted by justintime
    Is it similar to this one from kawamall seller?
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5786102729
    Yes, like that one.
  4. #64
    Jul 2004
    Just bought one
    I purchased the one on ebay for $139.00. It's the one with CCD sensor and ir.
    The output quality is far superior than cmos based cameras. Also, I could not believe how powerful the IR LEDS are. The complaint from the original viewer on the spots display in the output , is dust related. The dust particles will display a faint white ring around the particle. The reason is the powerful IR LEDS.
    Another note, the interference is caused by using very cheap RCA cable for the video input. Cheap cables do not make a great connection. When I replaced the cheap cable with one that had a better connector and better shielding, the picture was crystal clear.
    I'm happy with my purchase. The quality of this high price camera shows.
    Dwaine.
    2003 Black Impala
  5. #65
    Jul 2004
    Try a different RCA cable
    Quote Originally Posted by shotgunefx
    Doesn't matter how I power it. I initially tried it on a 12volt portable battery and a wall wart, same thing. It's not bad at all. But for what they cost new, I would have thought it would be crystal camcorder clear.
    My camera is clear. It was not when I used a cheap RCA. Change it... You will see the difference.
    Dwaine.
    2003 Black Impala
  6. #66
    Mar 2005
    Quote Originally Posted by Dwaine
    Dwaine.
    do you mind share the make/model of the one your purchased?
  7. #67
    Oct 2005
    Hou. TX
    Have you guys seen the camera's at Fry's? They have several in their security section. Most all of them run on 12 volts and the prices are very good($40-$80).
  8. #68
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Just thought I'd post this for posterity. I measured the field of view of the Savv VAC-5000 using two quarters and a tape measure.
    It's ~139 degrees horizontally.
    Just wish the pic quality was better. Sometimes, it's crystal clear, others, I get a bit of black snow. Think somethings up with the auto-iris.
  9. #69
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    As long as it's not yellow.
  10. #70
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Just bought this one on ebay - 120 deg field of view, night cam w/IR, meant to be installed in keyhole (looks very similar to pics above). $50. Will post review when I get it. My thinking on this is that it's backup camera, not going to be used to photograph people or anything that needs to be high resolution - I just want to see if I'm about to back over anything.
  1. 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
    By tbird2340 in forum The Review Palace
    Last Post: 01-11-2005, 04:30 PM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 02:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 06:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
