Results 1 to 10 of 12
Thread: someone please explain to me why this is happening
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    My computer automatically restarts itself. i hit shut down and it just boots right back up. I tap the power button, same thing. The only time i can get it off is when i hold the power button for 4 seconds or cutting the power all together. I did tell my bios to wake from S3 standby on usb command but that was a week ago and these problems just started. Doesnt matter if i'm using my SDC or not, same effect occurs. HELP
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    DOUBLE check your windows power options as well as your bios options.
    EDIT: try disabling the USB option and seeing what happens
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    what kind of psu are you using?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    possibly bad ram, coincidently getting tripped when windows is trying to shutdown
    PC Components:
    My work log
    Woodbridge, VA
    Blog Entries
    53
    PSU is a standard 200 watt morex running to inverter. Ya know bad ram could be the answer considering its a 512 dim and only 248 is showing up in windows.
    Dec 2002
    Illinois
    whoa same thing happened to me but I ignored it, then one day i heard a pop and then there was that odd smell of burnt plastic and then nothing. Now I have no computer to play with. I guess I could take it apart but I'm lazy and only have 56k at home.
    Aug 2002
    sounds like the ram is your problem then.
    Feb 2005
    Oklahoma
    unless he has an on board video card and then his ram will read what ever he has left after on board video takes it hunk.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Quote Originally Posted by 04scooby
    but onboard video using more than half the ram? I'd say it's more likely that you only have a 256mb dimm and 8 of that is taken up by video. How much RAM does BIOS say you have?
    for good measure, run memtest86 (google for it)
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Feb 2005
    Oklahoma
    I have seen it before, usually it was windows being screwed though and reporting the memory incorrectly. Happened alot when I was working for Gateway and windows ME was released. I second the idea of checking BIOS to see if memory is detected properly.
  1. Explain pulse width modulation
    By Lando in forum Fabrication
    Last Post: 12-19-2004, 06:45 AM
  2. What keeps happening to Dynamix 7" LCD Threads?
    By Tidder in forum LCD/Display
    Last Post: 07-16-2004, 10:53 AM
  3. Can somebody explain use of pressure plate!
    By JanneZ in forum Car Audio
    Last Post: 07-12-2004, 01:58 PM
  4. Replies: 7
    Last Post: 10-13-2002, 08:57 PM
  5. Can Anyone explain the concept of Grounding
    By mprover in forum General Hardware Discussion
    Last Post: 08-21-1999, 10:18 PM
