Results 1 to 3 of 3
Thread: usb radio and power antenna?
    Nov 2004
    South West
    I am using a laptop for my car pc with no head unit so i am looking for a usb fm radio but would like the antenna on my truck to only work when i listen to the radio. when it gets a +12v feed it goes up and when power is removed it goes down. any ideas on how i can make this happen and on what usb units are available in the uk that would work with frodo player or the like? thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    Apr 2005
    just tap the antenna power to a switched 12V in your car, so the antenna is raised when the car is turned on.
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    whatever usb radio you choose, if your up to it, open it up and use a multimeter to check a few lines and see if any go off and on when you switch somethign on it (ie. audio mute or an actual on/off function for the tuner). once you find that, wire it to a relay that switches a constant 12V line to the antenna.
    otherwise, id go with ming's suggestion.
    Your everyday carpc geek and tech guru at your service. *bow*
  1. HU Quality AM/FM RDS/RBDS Radio with Features
    By rando in forum Hardware Development
    Last Post: 12-04-2008, 01:11 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Antenna interference for radio
    By mpfjr in forum General Hardware Discussion
    Last Post: 01-30-2005, 06:40 AM
  4. control radio antenna power to go up via usb
    By dim-8 in forum General Hardware Discussion
    Last Post: 08-04-2004, 11:32 AM
  5. HELP! USB HUB FOR Laptop, how do I power it???
    By bankingdom in forum General Hardware Discussion
    Last Post: 05-21-2003, 07:33 PM
