Results 1 to 10 of 12
Thread: Powering a USB hub? 5v options?
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    Okay let's see here. I guess I'm trying to clean up my USB cables. If I get a 4-port hub for my center console I can run 1 cable to it and have my Lilliput and Powermate on it with no problems and still have extra ports for a card reader, OBD-II reader, whatever. Sounds good to me.
    This is the one I like. Now, how do I power it?
    I suppose I could run a 12awg wire off the 5v line of the Opus, but that would draw even more of it's very limited power. I'm pushing it's limits as it is. And it would also be annoying to run another wire (isn't this what I'm trying to avoid?).
    I could tap into the cigarette adapter's 12v line with a 12v->5v adapter. Think it could handle 2 amps for the hub (500mA x4) ? I could also use the 12v from my headunit's wiring harness. Where do I get one of those adapters anyway? I couldn't find it at radioshack. It has to be a regulated 5v right?
    Nov 2004
    NYC
    bump
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    You wont need a powered usb hub for those items mentioned. But if you still want to, you can just take a lead from the molex connector on your psu and run it to the hub.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Nov 2004
    NYC
    I don't want to use the lead from the psu because my psu is being stressed out as it is, plus that means I have to run another cable.
    The Powermate requires it's own USB port. It wouldn't play nice with the Lilliput and whatever else I wanted to put on a self-powered hub.
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    get one of these for every amp, and a nice little heatsink
    I think radioshack or someone makes 5V car adapters for charging your palm or other USB powered devices.....you could get one of those and do surgery....
    Newbie fastXR's Avatar
    Oct 2004
    Lakebay, WA
    I've been thinking about this as well.
    I think the right way to do this is have a 12v-5v converter connected to a relay. The relay is turned on by the 12v line on the PSU.
    I have a couple of other items that need power besides a USB hub. I think this is the way I am going to do it. A relay puts only a tiny load on the PSU.
    Nov 2004
    NYC
    I can tell this is gonna be one of those threads thats over my head I don't know what regulator does, I don't know what a relay does... I think I'll just run 2 usb cables up front and hope that nothing needs too much juice.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    That iogear is little bit bigger than some of the other harmonica type hubs so that it can store the cable inside, and the cable is only about 6 inches long. It's not something you really need for permanent placement. Also, if you get one with a USB mini jack it usually comes with a 3ft cable, or you can get a longer USB A to mni cable. Just one less connection.
    Jan 2004
    Jersey/NY
    fyi.. a regulator pretty much regulates the voltage... it takes that 12V-14V coming from your alternator and regulates it to 5V +/- X (where "X" is a small voltage, ideally 0).
    Relay kinda acts like a electrically controlled switch. If you connect the 12V from the power supply to the switch input of the relay, it'll suck up almost no juice. For all practical purposes, you can say it doesn't suck up any juice.
    But since that 12V from the power supply is set high only when the power supply is on, it'll turn on the relay, so the relay will pass the 12V-14V from the alternator to the regulator, which will then convert down to a clean 5V.
    WIthout the relay, you'd always get 12V to the regulator, wasting electricity when the power supply is off.
    Nov 2004
    NYC
    Thanks for the info
  1. USB Hub stays powered when I turn off car...any resolution?
    By Mears in forum General Hardware Discussion
    Last Post: 07-07-2004, 07:42 PM
  2. powering a USB hub
    By jusatry in forum General Hardware Discussion
    Last Post: 03-26-2004, 01:40 PM
  3. My experiences with various components...
    By Defiler in forum General Hardware Discussion
    Last Post: 01-27-2004, 01:49 PM
  4. powering some usb devices
    By cubanmoses in forum General Hardware Discussion
    Last Post: 10-08-2003, 11:23 AM
  5. Powering USB Hub
    By Zip-Lock in forum General Hardware Discussion
    Last Post: 10-15-2001, 08:45 AM
