Results 1 to 2 of 2
Thread: Overheating
    Apr 2005
    Queens, New York
    Overheating
    Hey....I am going to build a carputer system but i have been hearing that the VIA mainboards tend to overheat. I will most prolly put the case in my trunk or maybe under the seat. Does any1 have any suggestions to keep the cpu heat to a minimum? And where is the best location to put the cpu....i am going to have an opus 120 watt power supply.....with this case:
    http://www.opussolutions.com/modules...=article&sid=4
    Elsewhere
    Quote Originally Posted by Cheekz185
    Where have you heard that they tend to overheat?
    The CPUS are designed to be low-power and low-heat. Most of the VIA EPIA motherboards don't even have a cooling fan on the CPU, only a heatsink.
    But if you're really worried about it, use a fan or two to pull air across the heatsink. You shouldn't have any issues.
    How about the Wiki?
  1. is this an overheating problem?
    By warnockm in forum General Hardware Discussion
    Last Post: 07-28-2005, 12:48 AM
  2. Overheating concerns
    By chapstick in forum Newbie
    Last Post: 04-20-2005, 04:10 PM
  3. Opus....overheating...?
    By dapepster in forum Power Supplies
    Last Post: 07-12-2004, 02:08 AM
  4. Carputer overheating - processor guru's help
    By MikeHunt79 in forum General Hardware Discussion
    Last Post: 05-04-2004, 09:26 AM
  5. I think my amp is overheating....
    By Gutter in forum General Hardware Discussion
    Last Post: 06-05-2002, 11:49 AM
