Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Dual Sound Cards
  1. #21
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    wow how many offers do u have to sign up for to get an acct at driversguide?
    Debating on installing a carpc in my Jeep.....
  2. #22
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    dont bother. sign in with the following info:
    username: drivers
    pass: all
    Your everyday carpc geek and tech guru at your service. *bow*
  3. #23
    Tainted Love Cris's Avatar
    Romania
    I tried having dual sound cards with a PCI one and the onboard and didn't work, that's why I especially said "as far as I knew"...
  4. #24
    Banned
    Dec 2004
    Quote Originally Posted by djXternal
    when i try to install using the provided installer from the factory, it wont even let me attempt it because for some reason XP didn't detect the card
    If you mean that neither the Detected New Hardware notification bubble or the Add New Hardware wizard popped up automatically, there's good chance that the card is dead. In this case, try it in another machine.
    I'm guessing that the driver install freezes at a certain point because Windows is attempting to initialize the card. Assuming the card is good, this can be caused by an IRQ conflict. First you must check the IRQ by pressing the Pause button when the machine is booting and flashes your system resource table on the screen. This is the next screen after post, right before Windows begins to load. (You'll have to disable any boot logo either in bios or by pressing the appropriate key, which is often TAB.) Once you get a clear view of that table, you can see what is sharing IRQs with what. Some devices have no problem sharing IRQs, some do. If your sound card is (which will show as PCI MULTIMEDIA DEVICE) in conflict with another device, you can try to change its IRQ in BIOS setup. (You cannot change the IRQ from within Windows.) The best thing to do first though, is to simply free up some IRQs and see if the board reassigns them properly. You can disable LPT ports and COMM ports to gain a few free IRQs. Sometimes you can disable 'Assign IRQ to Video' or 'Assign IRQ to USB' to gain more, but those settings can break other things. Check the resource table again to see if your card has a new IRQ. Even if it doesn't, check to see if it works now. It often will. Usually (I want to say 'aftermarket') boards allow you to assign IRQs by PCI slot. You can try this, as well as physically moving the card to a different PCI slot. (Some slots always share an IRQ with another.)
    So this is what you need to do:
    1. Try the card in another machine if possible.
    2. Disable any unused ports in BIOS.
    3. Move the card to a different PCI slot.
    4. Try changing the IRQ in BIOS.
  5. #25
    Jul 2004
    Tampa, FL
    Ok i fianlly got this card working after about 8hrs of trying... the problem seemed to be with the drivers, i went through the list of em that vchat20 said to try on drivers guide and got an older version of the drivers to install and it eems to work fine now
  6. #26
    Jul 2004
    Tampa, FL
    Quote Originally Posted by Vchat20
    yes you can have 2 sound cards. i do here myself since the onboard card doesnt have a gameport. but to make use of both, the programs you wish to use have to have the ability to tell it what sound card you want it to use. i know winamp and windows media player can do this.
    How can you configure windows media player to use a secondary sound card?
  7. #27
    Jan 2005
    Warren, Ohio, USA
    go into the options under the devices tab. go into speaker properties and set for whatever sound card you desire.
  8. #28
    Jul 2004
    Tampa, FL
    do u happen to use frodoplayer?
  9. #29
    Jan 2005
    Warren, Ohio, USA
    nope. im a CF guy myself.
  1. Dual Sound Cards?
    By HummDinger in forum Hardware Development
    Last Post: 04-11-2007, 06:53 PM
  2. Two Instances of FP and two sound cards
    By djXternal in forum FrodoPlayer
    Last Post: 04-13-2005, 12:58 PM
  3. Dual Sound Outputs (No HU)
    By djXternal in forum Car Audio
    Last Post: 03-04-2005, 04:15 PM
  4. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  5. PCMCIA Sound Cards?
    By Bodgy in forum General Hardware Discussion
    Last Post: 07-05-2004, 08:12 PM
