Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Dual Sound Cards
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Dual Sound Cards
    Ok guys i want to have dual sound outputs for my carpc....
    i have one output in an on-board soundcard on my EpoX 8RGM3I...
    the second sound card i just received from a guy one ebay, nuthin real special but its a 5.1 surround card which is what i wanted... its a C-Media 8738 6 Channel PCI Sound Card...
    ok everything was great till i tried to install the sound card... when i try to install using the provided installer from the factory, it wont even let me attempt it because for some reason XP didnt detect the card, but if i do finally get XP to see the card, i try to install using the XP "Found New Hardware Wizard" i point it to the xp drivers on the provided cd, and it tries to install
    everything looks like its installing fine until it gets to what seems to be the last file that needs copied "cmuninst.dat" and the computer doesnt freeze but the installer doesnt seem to continue just sits there and says its still copying cmuninst.dat
    any ideas?
    Debating on installing a carpc in my Jeep.....
    Tainted Love Cris's Avatar
    Romania
    As far as I knew you coudn't have 2 sound cards on a pc, but that;s just what I know...
    Jul 2004
    Tampa, FL
    i was told by some others on here that it was possible
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    I had dual sound cards on an old PC once. Installed like butter though. Are you sure the CD is good? Try installing drivers off the cd onto the HD then isntaleld the soundcard from there?
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    yes you can have 2 sound cards. i do here myself since the onboard card doesnt have a gameport. but to make use of both, the programs you wish to use have to have the ability to tell it what sound card you want it to use. i know winamp and windows media player can do this.
    Your everyday carpc geek and tech guru at your service. *bow*
    Jul 2004
    Tampa, FL
    yes i only need one of my front ends to use the onboard sound, and the rest to use my new soundcard... but that shouldnt be a problem... my problem is the installation of the drivers
    Jan 2005
    Warren, Ohio, USA
    did you try the drivers from here: http://www.cmedia.com.tw/download/OS...738_WDM_OS.htm ?
    Jul 2004
    Tampa, FL
    ill try those now... and wow thats got to be the slowest server ive ever seen... it took me almost 5 minutes to d/l a 2.44MB file when im on Fios
    Jul 2004
    Tampa, FL
    ok i tried the new drivers and the setup program runs, but does the same thing as the old setup program, says "Waiting for sudio driver to be ready" and had little dots accumulating underneath it for a very long time...
    any other ideas?
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Note that on many mobos onboard sound and video do not live well with plug-in cards.
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
  1. Dual Sound Cards?
    By HummDinger in forum Hardware Development
    Last Post: 04-11-2007, 06:53 PM
  2. Two Instances of FP and two sound cards
    By djXternal in forum FrodoPlayer
    Last Post: 04-13-2005, 12:58 PM
  3. Dual Sound Outputs (No HU)
    By djXternal in forum Car Audio
    Last Post: 03-04-2005, 04:15 PM
  4. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  5. PCMCIA Sound Cards?
    By Bodgy in forum General Hardware Discussion
    Last Post: 07-05-2004, 08:12 PM
