Is there an IR device that with a software (skinnable or we could with the library to control it over VB6) that can act as a remote control??
Like there are for Pocket PCs and smartphones!!
I want to have ym proccessor's remote on the PC!:)
Printable View
Anyone!!:(
yes, its possbile, you just need any remote, and an ir reciever. then you train the reciever to recognize the remote's patterns and you're off.
I only have IRMan.. Will it work? How do I train the receiver? With which app?
Not sure I totally understand. The IRMan is a receiver, it isn't able to transmit data.
However if you are looking at trying to control software with a normal (TV,Video,etc) remote control and the IRMan plugged into a PC, then there should be a wealth of software out there. Try looking at the evation web site: http://www.evation.com/software/windows.html
Not sure how much of it is skinnable though, but once it's setup you don't generally need to play with it again.
I use girder for that!!!
I want a device/software that can transmit certain IR codes!:)
yeah the UIRT is built will transmit and recieve codes. It was 5 years since i built mine so I suspect there is a new version - possibly with USB now. Really easy device to make.
here you go... http://www.fukushima.us/UIRT2/
