Results 1 to 10 of 12
Thread: Connecting to battery
    Raw Wave justintime's Avatar
    Apr 2005
    Probably the dumbest question ever, but when you guys attempt to power your Opus or other CarPC PSU, do you wire it directly to the battery + and - terminals? You literally pass a cable through the car's firewall all the way to the battery, or do you just tap into ANOTHER 12V cable this side of the firewall?
    How about the audio amplifier?
    I'm good with software and hardware, the electrical part of this project will be challenging
    Most complex thing I've built is a MAME cabinet, so I'm half competent -- I guess!
    Tainted Love Cris's Avatar
    Romania
    The positive wire MUST go all the way through the car's firewall to the car's battery. The GND can be connected to the - from the battery, but in almost all cases it's connected to any solid part the car's chassis.
    Newbie pixelflash's Avatar
    Dec 2004
    I have a inverter that is +tive from inverter, thru firewall to +tive post of battery. -tive cable is grounded to car chassis near inverter (about 9 in. of cable). Try to ground your power supply as close to it (supply) as you can - I think you avoid ground loops and other EMF issues that way. HTH.
    7" Innovatek 7002S - 900Mhz Abit KT7A mobo - 120Gb boot drive - 180Gb secondary drive - Mini-ITYPE2 keyboard - USB wireless mouse - Deluo 201 GPS - Vector 750W inverter
    Apr 2005
    NY - USA
    Don't forget the fuse as close to the battery as possible.
    Dec 2004
    Definitely include a fuse. I am running 8ga wire with a 30amp fuse about 4 inches from the battery on the positive line.
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    im so jealous you have a mame station/cabinet
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    Newbie Stray's Avatar
    Feb 2005
    Belgium
    Why does the fuse have to be as close as possible to the battery?
    I'v put mine at the end of the cable, a few inches in front og the PSU. I don't think it matters because this is currently the only device on the cable.
    Stage 1:[||||||||||||||||||||] 100%
    Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
    Apr 2005
    I believe the reason is just in case the cable itself gets shorted to ground (car chasis).
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by Stray
    Its so if you short the cable the battery wont explode. My firend exploded a battery before.
    The fuse will do no good if its on the far side, and the cable grounds out before it.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Apr 2005
    No problem with that.... if you don't mind your car being on fire
    Sorry about the sarcasm, i couldn't help. If the wire shorts somewhere before the fuse(the firewall for example), thats not good. I've seen an 8 gauge wire short to ground without a fuse...nasty. Imagine that wire getting hot enough to glow red and all the insulation melting and catching on fire, but it'll finally stop when the battery cables melt right off the battery under the hood.
    Don't hook an unfused wire to the battery... ever!
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 11:45 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  3. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 02:47 PM
  4. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 09:10 PM
  5. Connecting Ignition and Battery ITPS Wires
    By Norrin302 in forum Power Supplies
    Last Post: 03-03-2004, 10:01 PM
