Results 1 to 9 of 9
Thread: Forgot how to wire "reverse polarity" switch
    May 2004
    NJ
    Guys, as the title says, I forgot how to wire a switch so that the + & - are reversed. Also, I forgot which switch I should use. Thanks.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    :-P if i knew how i would help you but im just a post whore hahah
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    please be a bit more exact, i do not understand the question
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    is this for a forward/ backward motor? I think a 3 way switch ie center is + in then one outer is + out and other is - out
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    May 2004
    NJ
    WebDog, the answer is yes, I need to drive a motor one way and then flip the switch to run it the other way, that is what I need. looks like you know what I need, mind telling me what to do. thanks
    Sorry guys I was not clear.
    xdjxklusivex: I would not read a post if you weren't in it
    Here you go:
    Dual ON-ON
    Double Pole, Double Throw = DPDT
    A pair of on-on switches which operate together (shown by the dotted line in the circuit symbol).
    A DPDT switch can be wired up as a reversing switch for a motor as shown in the diagram.
    ON-OFF-ON
    DPDT Centre Off
    A special version of the standard SPDT switch. It has a third switching position in the centre which is off. This can be very useful for motor control because you have forward, off and reverse positions. Momentary (ON)-OFF-(ON) versions are also available where the switch returns to the central off position when released
    1990 Jeep Cherokee
    May 2004
    NJ
    This is exactly what I want. Thanks much, apreciate the help.
    Feb 2009
    help would be great
    I see you know what you are talking about... the only problem is I dont. I was searching on how to do this with a relay, but I could only find out how to do it with a dpdt rocker switch and not a relay. Can you please help me out? I have a relay with 8 contact points and I have no clue what one does what.
    I need to turn my car on and the power makes a motor move up. then I need to turn the car off and the motor go the other way.
    I understand that when I turn the car off the power goes as well, but I need to find out how to get arund this along with getting this relay to work.
    Sep 2009
    Quote Originally Posted by WebDog View Post
    Here you go:
    Dual ON-ON
    ON-OFF-ON
    DPDT Centre Off
    Just wanted to say thanks for the diagram.
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 01:29 AM
  2. Need to find acc wire that stays alive during crank.
    By Bobby Digital in forum Power Supplies
    Last Post: 02-05-2004, 05:42 PM
  3. how to wire a status LED?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 12-19-2003, 10:11 PM
  4. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 10:58 PM
  5. ATX power switch
    By mtmsol in forum Power Supplies
    Last Post: 05-13-2001, 12:22 PM
