Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: hard drive mounting questions
  1. #11
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    yeah. like i said above. take the time to mount it right so it has very little chance of the heads colliding with the platters. its not like you are making a huge warranty-voiding change to the drive. just mount it vertically and parallel to the car and you will be fine.
    but also, like already stated, very few people here have had any troubles with their drives running in their vehicles. most drives are hardened against some serious G forces (got an old 3GB seagate medialist here and it lists right on the label that it can withstand up to 75 G's)
    Your everyday carpc geek and tech guru at your service. *bow*
  2. #12
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    All of those concerns are very unlikely. It is rare for HDs to fail. Even if you drop one several feet to a concrete landing. Orientation does not matter in a car.
    TruckinMP3
    Read the FAQ!
  3. #13
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by TruckinMP3
    Unless you've got a maxtor
  4. #14
    Jan 2005
    Warren, Ohio, USA
    agreed on that one. this computer riginally came with a nice, thin, sleek 40GB maxtor. computer was manufactured in March 2003. it died sometime during may 2004. the current drive in it is a 60GB IBM Deskstar which has been chugging along since around xmas 2001. it originally was part of an old buslink drive.
  5. #15
    Quote Originally Posted by Vchat20
    That's most likely non operating shock though. It certainly is on newer drives.
  6. #16
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    i'm going to have to agree with truckin on this. as long as the hd is mounted firmly to the car...there won't be any problems. if you disagree please find the threads where people state that their hard drives died because they've mounted the hd horizontally, instead of vertically. as mentioned numerous times before, if you create such an impact in that the head hits the platters, you have bigger things to worry about then the hd...
    rebuilding carpc... kinda..
  7. #17
    Jul 2004
    Berkeley, CA
    Wow! You're having better luck with a deathstar than a maxtor Its funny and sad at the same time
  8. #18
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Arathranar
    Exactly!
    Quote Originally Posted by fantomas
    Well, there are some WICKED potholes on my friend's hill. When I drove up on it, I was within a few mm of bottoming out
  9. #19
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    I've got a Maxtor 80GB 2MB and it's worked fine for over a year. It sits flat ont he floor of my car inside a micro ITX case.. It's firmly secured and hasn't skipped a beat, mind you my car is lowered and I do go down lots of bumpy roads.
    CAR INFO HERE
    "He who dies with the most toys, wins".
  10. #20
    Jun 2002
    Colorado
    Quote Originally Posted by 0l33l
    Actually Maxtor is the only drive I buy, Desktop and car installs.... Not one issue... EVER
    TruckinMP3
    Read the FAQ!
  1. dead hard drive...
    By tapper1999 in forum General Hardware Discussion
    Last Post: 11-09-2005, 12:31 PM
  2. USB hard drive and hibernation
    By Chairboy in forum General Hardware Discussion
    Last Post: 11-12-2004, 05:39 PM
  3. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 02:49 PM
  4. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
  5. Idea to protect the hard drive...
    By Szech in forum General Hardware Discussion
    Last Post: 01-29-2001, 10:55 AM
