Results 21 to 30 of 34
Thread: hard drive mounting questions
  1. #21
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by TruckinMP3
    Actually Maxtor is the only drive I buy, Desktop and car installs.... Not one issue... EVER
    I'm never going to touch maxtor again. POS drives.
    I'm only going with Western Digital and Seagate drives. Never had a problem with any of those brands.
  2. #22
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    are western digital HDs good for mobile use as i have several
  3. #23
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    i have 3 120 gb WD hard drives..2 in my home pc and 1 in the car. no problems so far from any of them
    rebuilding carpc... kinda..
  4. #24
    Apr 2005
    Minnesota
    I've seen almost every major brand of hd mentioned here die...but i do have a preference for Seagate. They have a good warranty program.
    Da_Kooz
  5. #25
    May 2005
    NYC
    Quote Originally Posted by fantomas
    firmly to the car...
    I was thinking of soldering some springs to a piece of aluminum and mounting the hd to the plate. It's starting to sound like overkill. Opinions?
  6. #26
    Nov 2003
    CT
  7. #27
    Apr 2005
    Minnesota
    Like he said, if you wish, use rubber washers but bolt it down tight.
    Da_Kooz
  8. #28
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by giddonah
    That will add repeating motion and is generally accepted as bad.
    Mount it firmly to the car.
    TruckinMP3
    Read the FAQ!
  9. #29
    Quote Originally Posted by da_kooz
    Not too tight. The point of the rubber is to damp vibrations. If you do it too tight, it'll degrade that. If you do it too loose, it'll still vibrate. Firm is what you want. Not too tight, not too loose.
    Rubber washers will also significantly cut down on hard drive noise since it prevents that transferring to the sounding board that is your case...
  10. #30
    May 2005
    NYC
    gotcha. thanks. Firm. No problem.
  1. dead hard drive...
    By tapper1999 in forum General Hardware Discussion
    Last Post: 11-09-2005, 11:31 AM
  2. USB hard drive and hibernation
    By Chairboy in forum General Hardware Discussion
    Last Post: 11-12-2004, 04:39 PM
  3. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  4. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 08:07 PM
  5. Idea to protect the hard drive...
    By Szech in forum General Hardware Discussion
    Last Post: 01-29-2001, 09:55 AM
