can i mount a hard drive vertically and standing up? So flat against a wall as an example standing straight up tall?
anyone see problems with that?
Printable View
of course you can, most poeple recommend vertical anyway (personally i dont think it makes a difference), I dont see any issues with it being standing tall.
just make sure that its mounted parallel to the car so that if you make a hard stop, the read/write heads dont go crashing into the platters and totally ******* up the drive.
Quote:
Originally Posted by Vchat20
BS.... it does not matter what orientation. Mount it firmly to the car.
Any 'potential' HD failure will probably happensitting on a desk or be power related (not well regulated). Several desktop drives have been in aut crashes and not suffered a failure... Mine has been in several and is fine.
thanks guys
People have been fighting over this for years. Personally, what can it hurt to be extra cautious unless it's a mounting issue.Quote:
Originally Posted by TruckinMP3
It is a mounting issue. Firm mount and orientation does not matter. I have been in on most of the threads for those years you mention ;) We have even seen a HD engineer state the the surfaces of drive platters are mostly un-scratchable due to the process used to make them ;)Quote:
Originally Posted by EBFoxbat
But can't you misalign the heads or bend the heads if they hit each other?Quote:
Silly Octopus...Quote:
Originally Posted by 0l33l
The heads couldn't hit one another.
they could, however, hit the platters. That would be, as they say, bad.
Yeh, I meant waht would happen if the heads hit the platters. Guess I phrased it wrong :confused:Quote:
Originally Posted by DarquePervert
