Results 1 to 10 of 13
Thread: Please post Mobile Athlon compatible MOBOs
    May 2004
    NJ
    I know it is mentioned here some where but there is no clear cut way of knowing which mobo is compatible with M Athlon, I am not looking for the HW hack, I am just looking for a mobo that uses the M cpu out the box.
    Newbie Pyrotek's Avatar
    Feb 2005
    NJ
    Biostar M7NCG, also allows custom clocking out of the box. There are others as well. I'm using the Biostar.
    M7NCG w/ mobile 2400+ | 512mb DDR400
    3.5" HDD | Slim DVD/CD-RW
    Linksys USB Wifi | Belkin USB BlueTooth
    Opus 150w | Xenarc 7"
    RoadRunner - Thanks Guino!
    Elsewhere
    Shuttle SN41G2 for the barebones or FN41 for just the motherboard.
    How about the Wiki?
    Mar 2004
    California
    Pyrotek, what case are you using? What power supply?
    Kevin
    Audi A4 Carputer, 80% setup.
    Oct 2004
    South Carolina
    i assumed any motherboard will work fine with an athlon XP-M that supports athlonXP's ...
    I've tried in all my boards Biostar m7ncd Pro ... a mini ATX board, etc.
    if you want to OVERCLOCK IT, that's a different story. you have to have access to the BIOS to change frequencies and voltages. you can still do it with some wire tricks (i've done it!) if you BIOS doesn't allow that stuff
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by mattress
    No!
    You need access to the FSB and mulitplier for any mobo running a mobile athlon as they don't report it to the mobo like normal ones do. You can do the wire mod to force it if you don't have access to these but i would prefer a bios solution.
    If you don't do this they run ar the minimun speed of the CPU. normally around 800mhz
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Scouse Monkey
    No!
    That is correct.
    Been there and done that.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Raw Wave justintime's Avatar
    Apr 2005
    Im gonna watch this thread. Interested in what's out there... I had no idea a Laptop CPU could be used on a regular mobo. Are these low powered CPUs? Do they require fan cooling? Sounds like this could be a nice alternative to the rather underpowered VIA EPIAs
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Elsewhere
    Quote Originally Posted by justintime
    Yes, they are low powered CPUs. There are versions that draw 35w and 45w. They still require cooling, but anywhere near as much as a standard AthlonXP. That means using low-profile coolers (designed for 1u or 2u rackmount servers) is an option to save space.
    They also support the PowerNow spec, which will throttle the CPU to save power while under battery. That doesn't necessarily apply for a carPC, though.
    How about the Wiki?
    Mar 2004
    Bristol
    nice thing is they are lower power and run cooloer but they can also be underclocked further and the voltages can be reduced below what normal XPs run at saving a lot of power.
  1. Mobile Athalon XP
    By vcbb5 in forum General Hardware Discussion
    Last Post: 05-09-2005, 04:06 PM
  2. Amd Athlon XP to Mobile Athlon Conversion
    By Quattro in forum General Hardware Discussion
    Last Post: 01-25-2005, 08:43 PM
  3. A7N8X-VM/400 & Athlon XP Mobile?
    By Coeus in forum General Hardware Discussion
    Last Post: 01-16-2005, 06:39 AM
  4. Replies: 2
    Last Post: 04-16-2004, 04:04 PM
