I would recommend a SanDisk Exteme III card or if your on a budget a Kingmax Platnum CF card. Extreme III has a transfer rate of about 15 mb/sec, which is still substantially slower than even most 4,200 RPM laptop hard drives. You really only need a CF card if you're going to be offroading or if you are driving over potholes constantly.
newegg.com has these cheap. Otherwise use a 2.5" laptop hard drive if you're concerned with hard drive data loss. I am using a Toshiba 2.5" 5,400 RPM drive w/ 16 MB cache combined with a Maxtor DiamondMax Plus 9 series 80 GB 7,200 RPM 8 mb cache 3.5" drive. The Toshiba has the OS loaded on it with minimal stuff loaded (firewall, spysweeper, mcAfee antivirus, Epson printer drivers to my Epson C84 printer etc). This was I can have a drive that can withstand some shock (200 G of shock on the Toshiba) and cheap space for MP3's (only 60G of shock tolerance, which is probably actually ok even for a car).
Anyway you stack it, Windows will take up like 2.5 gig of space for an install. You can cut it down, but Microsoft doesn't want you removing the goodies. I would pick your options wisely when installing.
CF is expensive. As an alternative you could gut a iPod mini and take out the IBM MicroDrive and use that instead. Those are 3,600 RPM (SLOW), but have a very good shock tolerance rating. A 4 GB iPod mini actually is cheaper than a 4 GB IBM Micro Drive lol sometimes.
-LAKORAI
LinkBack URL
About LinkBacks
