Results 1 to 9 of 9
Thread: Wake from Standby in the Middle of the Night
    May 2005
    In any of your projects where someone is actively "syncing" content (whether it be music, video, RSS feeds, etc.) from the CarPC to a workstation or server in your home, can you comment on what method you used to do so?
    In particular, I have a laptop that is to be used as my CarPC, and although I know I can make it wake up from standby in the middle of the night and run a task (at least that seems to work inside the house on one of my Media Center XP machines) I'm curious as to the "gotchas" that might be involved in this. I have the laptop set to go to standby after 1 minute without power normally, I'm wondering if it wakes up from that in the middle of the night to grab some files from my server whether it will just go right BACK to standby after 1 minute of activity.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Just try it.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I have my carputer start syncing up when it detects shutdown. It cancels the shutdown and if it detects my home wifi connection it begins the transfer and will shutdown the computer once it finishes. If it doesn't finish in 5 minutes. It pauses the transfer and the resumes the shuts down automatically. I have an OPUS too so if for some reason the program crashes or the computer doesn't turn off when it should, the OPUS will force it off after 15 minutes.
    The big problem I see with resuming the computer is you'll have to worry about extraordinary circumstances more. Particularly at boot time if you get a BIOS error the computer will stay on showing the error same thing goes if the OS or your sync software fails to start. Then you also have to worry about how your going to turn on and off your computer for these special conditions as well as when you want to use it normally. i.e. Wont the computer just go into standby while syncing files if its set to go into standby after 1 minute of being without power?
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Mar 2004
    Vancouver, BC, Canada
    Quote Originally Posted by god_of_cpu
    What software and settings are you using to achieve this?
    May 2005
    Software
    Exactly what I was going to ask next.
    Low Bitrate reefhippie's Avatar
    Dec 2004
    Tampa, Forida
    If you're running an FTP/TFTP/SSL server or whatever on the computer in your house, you can write a simple batch file and add it to the logoff section in your group policy.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    My Asus P4PE board has a wake at certain time function... don't know who the hell uses that on a full ATX board
    Dec 2004
    Tampa, Forida
    That's a great feature for Enterprise Network Administrators who are responsible for automating routine scheduled maintenance on desktops across the LAN/WAN.
  1. Standby issues. Seriously confused here.
    By maxxell in forum General Hardware Discussion
    Last Post: 04-16-2005, 02:26 AM
  2. Powermate wake from standby Help !!!
    By adrian_uk17 in forum Input Devices
    Last Post: 03-04-2005, 05:54 AM
  3. Standby or Hibernate w/ nlited windows
    By IntellaWorks in forum Power Supplies
    Last Post: 02-19-2005, 01:38 PM
  4. Returning from Standby killing Mediacar
    By Magpie in forum Software & Software Development
    Last Post: 04-01-2004, 02:36 PM
  5. Sierra Aircard Wake on ring?
    By Zip-Lock in forum Wireless Communications
    Last Post: 03-04-2004, 12:30 AM
