Results 1 to 10 of 10
Thread: Secondary IDE device not found?
    Low Bitrate gothate's Avatar
    Oct 2004
    I'm having problems getting anything attached to the middle of the IDE cable to work. Is there a pin configuration for the Panasonic CD/DVD drive or something? I've tried the primary and secondary IDE sockets, only stuff in the 'master' position recognizes. I have an Epia MII12000
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    The Panansonic CD/DVD drive? I think they make more than one.
    I have a Panasonic CD/DVD CW-8123B (slim, slot-load). IIRC, it will only run as master on it's own channel.
    I hope that helps.
    Oct 2004
    Yeah *the* one
    At least the only one in the MP3Car store. Yeah, that helps a bunch. Where'd you find that out at anyway? Or just trial and error? Luckily, I had a second IDE cable laying around, but how much space do they think we have in these damn cases?
    May 2003
    SE Michigan
    Yeah, trial and error.
    And I believe that the drive was originally designed for laptop use, so...
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Try swapping Molex connectors. I had one with a pin spread open and the drive wasn't powering up.
    Fabricator
    Oct 2004
    I swapped cables, I swapped positions on the cables, I swapped power connectors, I swapped primary and secondary IDE ports, I swapped till I could swap no more. Definitely seems like it wants to be by itself. Does anyone have this drive on the same cable as a hard drive? If not shouldn't it be in a FAQ somewhere?
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    your slimline->ide adapter probably doesn't support slave setting ...
    [ 5-spd 1996 M A X i M A SE ]
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Its not about slimline to IDE adaptor. In fact, CW-8123B does not support master/slave setting feature, it is hardwired to a master position instead. There is no way how to make it detected as slave on any channel. The only chance is to connect it to the second channel, where it will be detected as master device.
    Oct 2004
    That's some handy info to know, now which faq to put it in...
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    you should put optical drived on a diff chanel to hds anyway, as optical drives are slower, and it works on a bus it will only be as fast as the slowest thing.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
  1. lilliput won't work - USB device not recognized...
    By aegray in forum Input Devices
    Last Post: 06-16-2009, 03:38 PM
  2. BIOS sees secondary IDE DVD, but XP does not...?
    By judoGTI in forum General Hardware Discussion
    Last Post: 08-08-2004, 11:31 AM
  3. Ide 2 Usb
    By arkadiyp in forum General Hardware Discussion
    Last Post: 04-06-2004, 08:40 PM
  4. How do I attach (2) ide cables together?
    By Scafremon in forum General Hardware Discussion
    Last Post: 01-03-2004, 08:21 PM
  5. found a good device to emulate keyboard commands
    By Birrman54 in forum General Hardware Discussion
    Last Post: 08-08-2002, 12:38 PM
