So you don't waste outputs on the serial port, use a DTS or RTS pin. I know VB is able to do this, but it depends on the library you use for the command. You can easily program the pin to go high for any amount of time by triggering a timer to go off, and then signal the pin to go low again. If anything, you can always program the STAMP to using the BUTTON command, and regardless of the length of the signal it would go off.
LinkBack URL
About LinkBacks
