Results 11 to 20 of 30
Thread: Anyone with knowledge of surveilance cards?
  1. #11
    Feb 2005
    here try this
    http://www.grandtec.com/xguard.htm
    100 bux
  2. #12
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Quote Originally Posted by Outsider
    It has only 20 fps to share among all inputs. And no SDK in sight. I think 60 fps is bare minimum, and SDK is the must - the card should be able to display one or two cams at the same time in specified screen regions. Sorry I didn't specify this upfront, I'm learning
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
  3. #13
    Apr 2005
    Why don't you just use a bunch of USB cameras?
  4. #14
    Apr 2005
    Seattle
    Quote Originally Posted by darkciti
    I've read it on multiple occasions that Windows doesn't work well with multiple USB cameras. I don't want to switch to Linux or other DIY system just to find that, although in theory they do support any hardware or combination thereof, it's all, well, DIY
    Still, if you out a how-to on connecting multiple USB cameras, please, enlighten me
  5. #15
    Apr 2005
    Seattle
    Quote Originally Posted by pate60
    actually i set up a simple carputer for a PI, based on a mini ITX a while ago, simple 4ch card, only used 2 channels, with front and back wide angle lens cameras, captured at 12 fps per camera. the card was only light $5 on ebay. worked a treat.
    Do you remember the name or the seller of that card? Did it come with SDK or did you have to use some stock software? Thanks
  6. #16
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    Multi Camera
    You have a lot of different options here.
    You can use camera's that just have a composite connector and connect it directly to your display (providing you display has a composite in connector). The 7" lilliputs do. You could create a hardware switch and add as many devices as you wanted.
    The disadvantage is you have no control over the image and you would have to manually switch your display to V1 input, you also couldn't record anything.
    Or if your video card had a composite IN connection you run camera's directly into it. Again using a hardware switch to select which camera is in use. This way you wouldn't need to switch Video Input and you could record the images.
    Or you can use USB. Windows XP does support mutiple camera's. I have a Logitech wireless camera and webcam running on my system without any problems.
    We have just integrated USB camera support into our software. You can connect multiple camera's but you are limited to viewing once device at a time.
    I am sure you will need a PCI capture card to get multiple camera's to display at the same time.
    Let me know if your interested I'll send you a free copy.
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
  7. #17
    Apr 2005
    Seattle
    Quote Originally Posted by 12Vsystems.com
    Thanks, that's the limitation I tried to explain - multiple USB cameras don't work well together. There is no reason your combination of USB + wireless camera should not work (ans so it does ). I'm pretty sure PCI card will work, I just have no idea which one to get
    Absolutely. As soon as I get my naughty hands on some camera
  8. #18
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    Quote Originally Posted by lastberserker
    nah dont have any info on it with me in the UK, but it didnt have SDK, and we used the software that came with the camera.
  9. #19
    Apr 2005
    Seattle
    Bummer
  10. #20
    Newbie fastXR's Avatar
    Oct 2004
    Lakebay, WA
    What about firewire cams? The apple iSight is very good and with firewire the bandwidth is there.
    The problem with USB cams is they are usb 1.0 which is fairly slow and cpu intensive.
    I don't know how well they work with windows, but they are fantasic under linux.
  1. Multiple video cards multiple audio cards
    By vipergda in forum General Hardware Discussion
    Last Post: 05-18-2005, 01:57 AM
  2. Psone compatible video cards
    By CavityCr33p in forum LCD/Display
    Last Post: 03-02-2005, 03:22 PM
  3. FS: 2 x Binatone WL1000 Air-Link+ 22Mbps PC Cards
    By buildfromscratc in forum Classified Archive
    Last Post: 08-01-2004, 11:29 AM
  4. Need advice for video/input cards
    By Strix in forum LCD/Display
    Last Post: 07-01-2002, 02:27 PM
  5. Securing cards
    By Reaper in forum General Hardware Discussion
    Last Post: 06-26-2002, 04:50 PM
