Results 1 to 10 of 10
Thread: 2.5" harddrive + CF adapter on same IDE?
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    will I have any performance issues putting my laptop harddrive and CF->IDE adapter (with CF) on the same IDE channel?
    basically, I need three things, just not sure on the IDE combination:
    1. CF->IDE adapter w/ CF
    2. notebook harddrive
    3. slimline CD/DVD drive
    the notebook drive will be used for media storage and maps. I plan on using the CF card w/ XPe and EWF ... and cd/dvd for whatever.
    [ 5-spd 1996 M A X i M A SE ]
    Raw Wave
    Jun 2004
    On the beach
    Can't see any problems there, although it may be better with:
    1st IDE Primary - CF-IDE
    1st IDE Secondary - Slimline Cd/DVD
    2nd IDE Primary - Notebook Hdd
    Mar 2005
    White Plains, NY
    Have you booted with a CF card yet? I have a 1gb microdrive and it's slower than slow to boot (not with the bios POST, I'm talking just windows 2k) and I have 512MB ram on an Epia 800.
    I'd use the notebook HD for whatever you can and put the cf-ide adapter so you can get at it from the outside and use the CF card to transfer files.
    Oct 2002
    San Jose, CA
    thanks guys, i'll try those combos.
    yeah, I have booted with CF and it's pretty quick .. just under 15 seconds with winlogon. I plan to change to minlogon and have my own GUI boot so I'll probably shave another 5-7 seconds and if I go with ReadyON or HORM , should be much more quicker.
    i'll let you guys know how it turns out. BTW i am using XPe.
    FLAC SFiorito's Avatar
    May 2004
    good cf cards (like the newer SanDisk's) are much faster than microdrives
    Mar 2005
    White Plains, NY
    Yes, that may be true. But, a Microdrive won't die as fast as a good CF card.
    May 2004
    that's why you use EWF on a CF card... i was actually surprised at the difference between microdrives and even average consumer level CF cards...
    http://www.robgalbraith.com/bins/mul...?cid=6007-6133
    Oct 2002
    San Jose, CA
    wow
    i am using:
    SanDisk "standard" 512MB SanDisk I 2004/4/6 2.099MB/sec
    maybe i should upgrade haha
    May 2004
    get an ExtremeI or UltraII. get an ExtremeIII if you don't plan on using standby or hibernate.
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    Why an Extreme III only if not using standby or hibernate? The CF card is not really faster to boot, correct? They are mostly just for vibration/shock resistance?
  1. SimpleTech 128M CF and CF to laptop IDE adapter
    By eugenen in forum Classified Archive
    Last Post: 04-04-2005, 02:10 PM
  2. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  3. WANTED: 2.5" to std IDE adapter
    By cybermob2 in forum Classified Archive
    Last Post: 03-25-2004, 11:10 PM
  4. IDE adapter without missing pin???
    By dank_Army in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:01 PM
  5. 2.5" harddrive adapter issue
    By LarryDoliver in forum General Hardware Discussion
    Last Post: 06-27-2003, 01:00 PM
