Results 1 to 3 of 3
Thread: MII 12000 Hardware acceleration does not work
    May 2005
    Unhappy MII 12000 Hardware acceleration does not work
    Hi there
    I have a MII 12000 mobo and DVD playback is jerky. I have tried powerdvd 5 and 6 and windvd 6 but each time I switch on hardware acceleration, the machine hangs. It will only work without hardware acceleration switch.
    I have upgraded all drivers to latest and tried all things suggested on other VIA forums. I can now get it to play at a reasonable rate but only without hardware acceleration switched on. If I switch it on, it takes ages to load DVD and to start playing.
    Is it because epia drivers are not yet up to scratch with powerdvd/windvd? Should I go back to previous versions of powerdvd?
    Any other suggestions- the reason I went with the MII 12000 was because of the MPEG2 hardware acceleration - now it stands idly by
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    I have the MII 12000 and don't have any probs with DVD playback. I have tried the hardware acceleration option but don't see any improvements on quality. How much RAM do you have? Where is the DVD player plugged into - usb, IDE, Firewire etc.? Post your PC specs!
    May 2005
    Specs:
    MII 12000 mobo
    512MB RAm
    Internal Liteon 16X DVD ROM (IDE primary channel)
    40GB Laptop 2.5" drive on IDE secondary
    Leadtek PVR PCI Card on single riser (audio from here plugged into mobo CD audio)
    REgards
  1. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  2. Epia Mii 12000 Issues
    By (6) in forum General Hardware Discussion
    Last Post: 01-09-2005, 03:24 AM
  3. VIA EPIA MII 12000 1.2Ghz Motherboard questions
    By arise360 in forum General Hardware Discussion
    Last Post: 12-30-2004, 01:38 PM
  4. VIA Epia MII 12000 Nehemiah Mainboard
    By RobIles in forum General Hardware Discussion
    Last Post: 07-07-2004, 08:04 AM
  5. hardware woes - just venting!
    By magnetik in forum Off Topic
    Last Post: 05-21-2002, 03:31 AM
