Results 1 to 10 of 10
Thread: Xm Sound
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Unhappy Xm Sound
    I ve searching for about a week now and cant find an answer my xm never gets siginal in frodo sat it just says updating on the preset buttons, media car just says initilizing xm channels ive double checked my cable about 20 times and im using the com port on the back of the pc and is set up as port 1. when I go into the device manager it dosent have anything listed do I need additional drivers? any help is appreciated
    thanks Aron
    Apr 2005
    2hr west of Chicago
    noone has any suggestions?
    Low Bitrate McFreak's Avatar
    Mar 2005
    McKinney, TX
    Try grounding the sheilding in the cable. Did you make the cable or buy it? Are you using an XM Direct or PCR?
    CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
    Apr 2005
    2hr west of Chicago
    I made the cable, im using direct, Im gonna try to ground the sheilding hope it works
    thanks Aron
    Mar 2005
    McKinney, TX
    Make sure the shielding on both sides are connected as well. I didn't have them connected and right when I connected them frodoSat started working.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    also make sure that it didnt find the XMD as a serial mouse, check the device manager under mice
    if it's there just disable it, dont delete it. then reboot the computer and it should work
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    and try this program, which will at least show you if your getting packets to the XMD you should see both S and R's in the window
    http://frodoplayer.com/downloads/XMDebug1.2.zip
    肚子笑痛了
    S60 Install
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Maybe a stupid question, but when you say it is setup as port 1, you do mean that you edited the .ini file and changed it to port 1 right? Just making sure.
    ATVMS.com
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I have the same issue when I use FrodoSatelliteRadioXAlpha3. It just sits there and keeps updating but nothing happens. But when I use the the embedded XM player within Frodoplayer front end it connects immediately and works just fine. I think I have edited the ini file correctly (but I could be wrong). My XM is not activated though so could it be that it cannot complete updates because it cannot find all the channels?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Apr 2005
    2hr west of Chicago
    wooooohoooooo I decided to hack a new cable together and now it works I just get a bad buzzin sound when xm is on unmute on line in and mute on exit are used so i got some searchin to do thanks to everyone for all the help
    Aron
  1. XM Sound Quality?
    By nFiniteTuning in forum General MP3Car Discussion
    Last Post: 01-29-2005, 11:20 AM
  2. XM PCR Optical popping sound?
    By judoGTI in forum General Hardware Discussion
    Last Post: 12-08-2004, 11:13 PM
  3. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
  4. Replies: 3
    Last Post: 06-05-2004, 12:23 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 09:01 AM
