Results 1 to 10 of 13
Thread: Pci Riser on SP13000
    Mar 2005
    Rome
    Hi all,
    as you can see in the attached image, Epia SP13000 have a dissipator near the pci slot. I fear the official Via Pci Riser is not tall enough to install a pci card horizzontally, this could touch the chipsets dissipator. I need to install two cards (Cinergy 600 and Audigy 2 zs) facing the motherboard (Right side PCI Riser I think). But in this way the card on bottom could not have enough space considering the dissipator mounted on the motherboard.
    So, few questions:
    1- There will be any conflict for the two cards running together? Better, can they operate on the same slot (Pheraps i need an active Pci Riser)?
    2- 3.3 or 5 V?
    3- Can someone suggest the right product (I've not been able to find the right product matching my needs)?
    Thanks all.
    Mercedes A Class 170 CDI
    Carputer Progress:
    [X---------] 10%
    Elsewhere
    Quote Originally Posted by Cancer
    Hi all,
    So, few questions:
    2- 3.3 or 5 V?
    Thanks all.
    I don't believe there is a 2-into-1 PCI riser.
    I could very well be incorrect, but I've never seen such an animal.
    How about the Wiki?
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    It exists, will it work ? I dunno Never used them..
    Feb 2004
    North Aurora, IL
    they do exist, i have one on my MII12000, and it works great, no problems yet with it.
    dont know what to say about the SP13000.
    Elsewhere
    Well damn.
    I've never been in the situation where I've needed a PCI riser, let alone a 2-into-1 riser.
    How about the Wiki?
    Maximum Bitrate DeltaFX's Avatar
    France
    Some miniitx boards allow 3-to-1 PCI riser.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by DarquePervert
    Well damn.
    damn noobs!
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    I have the MII 12000 and the Dual PCI Riser points the pci slots away from the mobo, not over it.
    Feb 2005
    Essex, UK
    Mar 2004
    Bristol
    Quote Originally Posted by rickster
    yeah that one in the pic above does too by the looks of the keying to the PCI slot.
  1. FS on eBay: selection of PCI and AGP risers
    By lemming in forum Classified Archive
    Last Post: 04-10-2005, 08:58 AM
  2. PCI Riser kills EPIA M10000
    By gizmomkr in forum General Hardware Discussion
    Last Post: 03-01-2005, 02:42 PM
  3. which pci riser sive for m10000?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 11-02-2004, 05:16 PM
  4. VIA EPIA Pci Riser - One that works
    Last Post: 09-21-2004, 11:48 PM
  5. New/Old ITX 2677 Case with PCI Slot and Riser!!!
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 08-12-2002, 02:28 PM
