Well, the LCD is useless without a controller. The controller converts VGA signal into a usable form of signal that is fed into the LCD.
I read that if you bought one of the Sharp Touchscreens on ebay mated with the 3m touchscreen piece you would need a "will definately need a conntoller, inverter and also a touchscreen controller if that" Could someone explain what the purpose/ function of each of these is ??
~H. Charles
cardomain.com/id/harlanc04
What if the LCD has a VGA input? It's not necessary then?
~H. Charles
Well, if its got VGA input then you're all set.Originally Posted by Harlanc03
Sweet, one more question then, what's the power source normally for a monitor? is it just through a direct fused wire on the battery? or from an inverter ?
~H. Charles
It's most commonly from either a fused wire on the battery or many people hook it up to their power supply to filter and regulated the power.
Inverter isn't usually necessary unless it's a desktop unit. Then all bets are off.
Want to:
Don't bid in that auction. That screen is an Sharp LQ9D161. Translation: Screen=crap.
1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
PC built into console
worklog with pics: http://www.mp3car.com/vbulletin/worklogs/46359-1999-plymouth-voyager-computer-in-console-between-seats.html
Some of my music: http://www.myspace.com/markquestion
