Are you sure you have the latest bios and drivers? (nice board btw)
I have a Commell LV-670 motherboard with the Intel 845 chip set. I love this MB and it boots quite fast. However i have a problem with usb 2.0
The bios and MB support the usb 2.0 and i do have the enhanced usb line in device manager. All checks out... however when i plug any usb 2.0 device into the port it will not work.
For example i purchased 2 Belkin tetra hubs. It has a light that will let you know the connection speed.
When i plug it in the 2.0 light is lit but it will not show up in windows. When i disable 2.0 in my bios it will connect at 1.1 and work just fine.
I tried installing all different drivers but none made a difference. Any usb 1.0 device i plug in works great, any 2.0 device will not connect unless i manually disable 2.0 in bios.
I am running windows XP sp2 with the LV670 motherboard.
-Jack
2006 Chrysler 300C AWD
Samsung Galaxy Tab In dash
Originally Posted by Scouse Monkey
Latest drivers however only 1 version of bios. Ver 1.0
-Jack
hmmm does sound like a bios issue. Have you emailled the manufacturer?
Hmm, look more closely at the BIOS maybe there's some weird setting that we're missing... For example telling the bios to use 2.0 or something..
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
I tried but no avail! There are 2 USB settings...Originally Posted by IntellaWorks
1. Enable Usb host controller
2. Enable High speed Usb 2.0
Both enabled
-Jack
Wait a minute? Could that be? I think im going to have to try it!
-Jack
What a retard... hahahah !
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
