Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Usb power and Standby
  1. #31
    Mar 2005
    Columbus, OH
    when you splice the usb extension cable, you will see 4 wires, red, black, yellow and green..
    the red and black are the ones we want to modify... the yellow and green can be left in tact...
    e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
    sold it all... :-(
    Coming Soon - 2007 BMW 335i UMPC install
  2. #32
    May 2005
    Rochester, NH
    right, I follow that, I just am trying to understand what this is doing... so I plug the extension cable into my hub, then the 5 volt wires to a modified ps2 connector... this just seems like I'm tying my two 5 volt sources together... I'm not sure what this is supposed to do, thats all.
  3. #33
    Mar 2005
    Columbus, OH
    Quote Originally Posted by dmcdlrn
    I don't think you follow... you are NOT tying your 2 5v lines together...
    right now, I AM ONLY USING 2 WIRES FROM THE USB PORT on the PC
    you do this BEFORE your hub, the extension cable will be connected between the PC and the hub, the PC end of the extension cable connects the yellow and green wires to the usb port on the PC, the red and black wires now go to the hacked ps/2 cable... THIS DOES NOT TIE YOUR 2 5v LINES TOGETHER... your hub has circuitry to keep the 5v seperate, but not activate unless it see's the 5v, therefore your hub is activating off of the ps/2 port, and powring from its own 5v...
    this makes the PC's 5v out of USB not used anymore, since this is what doesnt always turn on and off correctly...
    sold it all... :-(
  4. #34
    May 2005
    Rochester, NH
    Oh, Ok I follow now.. unfortunately my first hub inline is unpowered so that won't work. So my ps2 port switches off when the computer goes off?
    Could I power that unpowered hub off of the ps2?
  5. #35
    Mar 2005
    Columbus, OH
    yes, thats what its for... instead of just activating it(like in the case with a powered hub), it will power it too... your ps/2 should switch off with the computer (or you would see your optical mouse stay lit if you ever used one on it)
    All we are doing is ditching the 5v that the USB port gives out, and stealing the 5v from the ps/2 port. It will work with any usb config, powered or non powered... its essentially the same thing, just powered off a different bus.
    sold it all... :-(
  6. #36
    May 2005
    Rochester, NH
    Ok, supposing that I was to do this, does anybody know how much I can draw off of that ps2? does it have a over current protection circuit like usb does? If I could get rid of the power inverter I would be really excited!
  7. #37
    May 2005
    Rochester, NH
    Anybody know how much the ps2 ports can put out mA wise?
  1. How to cut usb power when in standby
    By Goddy in forum General Hardware Discussion
    Last Post: 03-14-2005, 02:28 PM
  2. laptop power when in standby..
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 02-17-2005, 05:44 AM
  3. power usage in standby
    By grahamrb in forum Power Supplies
    Last Post: 02-11-2005, 09:31 PM
  4. OPUS can't retain standby power
    By bdqpdx2000 in forum Power Supplies
    Last Post: 11-22-2004, 09:16 PM
  5. S1 Standby Power Consumption Drain Battery?
    By Grayscale in forum General Hardware Discussion
    Last Post: 06-16-2004, 02:30 PM
