Results 1 to 10 of 10
Thread: 4-port USB Hub burned
    Low Bitrate DaKyy's Avatar
    Apr 2005
    Finland
    Unhappy 4-port USB Hub burned
    Don't know where the problem is, today I started the car and the hub was dead. The powerled didn't lid up. I got the 5V vdc out of M1 5V line. It worked fine yesterday, altough, the whole system was installed yesterday. Is the engine crank responsible? Any similar experiences?
    Apr 2005
    Finland
    What hubs are you ppl using? I checked the 5V line, and it was quite straight, no bumps at all. I hope the next one doesn't burn - maybe I should use passive hub.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    was it a brand new hub or was it used?
    maybe it was just it's time to go
    肚子笑痛了
    S60 Install
    Apr 2005
    Finland
    Just bought it
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Make sure you don't reverse the polarity. That white stripe is usualy positive, but not always so check and make sure anyway. That's what killed mine.
    Apr 2005
    Finland
    Yeah, I double checked everything before connecting anything, and the hub worked fine. Not today though - no go.. Every gadget works though, so it didnt wreck those. Perhaps some loose wire got to it... I also checked with voltmeter. I Think I'll triple check it just to make sure
    Apr 2005
    Finland
    oh yes it worked again today... but it stopped again in the evening. I figure this is because of minlogon. I'll test with the normal winlogon to see if it helps. Minlogon seems to be really buggy with usb devices...
    Apr 2005
    Finland
    Yes, it was the minlogon. So, back to using the ol' winlogon.
    Mar 2004
    Florence Yall, BFKY
    Well, an inexpensive mistake at least. Hubs are generic though, no drivers needed. It shouldn't really have any trouble.
    Apr 2005
    Finland
    When it's not working (with minlogon), windows device manager shows unknown usb device. Also devices connected to it don't work. When i swich back to normal winlogon, it detects it and the devices correctly. It works with minlogon after that though, but not for long, the same problem reappears after few hours/days.
  1. USB Mouse in USB Hub
    By patrol in forum GPS
    Last Post: 06-14-2005, 11:35 PM
  2. cut AC transformer off USB Hub power to connect DC?
    By ITL in forum Hardware Development
    Last Post: 04-23-2005, 03:19 PM
  3. Best USB Hub
    By nsmoller in forum Input Devices
    Last Post: 02-08-2005, 03:35 PM
  4. USB 4 port extenders
    By illwill in forum Hardware Development
    Last Post: 02-06-2005, 02:01 PM
  5. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 06:06 PM
