Results 1 to 9 of 9
Thread: Which HD solution is better?
    Newbie MrLister's Avatar
    Apr 2005
    Vancouver
    Post Which HD solution is better?
    Is it better to get
    1 3.5" http://store.westerndigital.com/product.asp?sku=2622727 (320GB total using 9.00 watts)
    or
    2-3 2.5" http://store.westerndigital.com/product.asp?sku=2593542 (160GB to 240GB using 5.00 to 7.50 watts)
    One uses less watts but then has 3 drives whereas the other one is one big drive.
    Which one would you say is better? I plan to store music, movies, and other files on the computer.
    MrLister
    Learning Status: |#####-----| 50%
    System Setup: |----------| 0%
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    2.5" hard drives can handle more shock, but don't have as much storage capacity. I would recommend a 3.5" drive if you want the storage space.
    Apr 2005
    Vancouver
    Elsewhere
    Quote Originally Posted by MrLister
    Is it better to get
    or
    I don't think it matters much, if at all.
    I also don't know what you mean when you say that one consumes less watts but is three drives? That makes no sense whatsoever.
    Some have said that 2.5" drives (designed for laptops) are better because of their resistance to shock and whatnot. That may very well be true, but there are a lot of others that use only a 3.5" drive (designed for a desktop) and have had no problems whatsoever.
    Also, keep in mind that the 2.5" drive requires a an adapter (like this) to connect to a standard IDE cable.
    How about the Wiki?
    Raw Wave tj!2k4's Avatar
    Oct 2004
    If you need the storage, just go for the 3.5".
    It's not like you're going to save any space by using the 2.5" drives, in fact you may cause yourself more of a headache because (depending on your enclosure) you have to accomodate more drives. And wattage-wise you'll wind up consuming more with multiple 2.5" drives as opposed to one 3.5" as well..
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    what kind of power supply will you be using? If there's any chance your 12v rail will be the slightest bit unstable (i.e. using an ITPS) then go with a laptop drive.
    I always use laptop components simply because they consume less power and I get the most out of my supply.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Low Bitrate reefhippie's Avatar
    Dec 2004
    Tampa, Forida
    Why not use a small laptop drive in the main case for the OS and applications and keep all of your music and movies on external USB laptop drives that you can easily take with you?
    Oct 2003
    Atlanta GA
    that's not a bad idea but as I recall a number of people have issues with USB devices flaking out after hibernate/standby.
    My JeepPC Install
    Dec 2004
    Tampa, Forida
    Quote Originally Posted by shakes
    Still? I thought that was supposed to be cleaned up with SP2. I haven't tried it recently.
    I figured I'd be taking mine into work with me or whatever so I could listen to it on my laptop, but I guess that would be a PITA to have to unplug it and plug it back in if you just stopped to run into the store or something...
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. a serious solution
    By sohaibma in forum Power Supplies
    Last Post: 04-06-2005, 03:44 PM
  3. IDE EXTERNAL HD Pt-2
    By PaCMaYNE in forum General Hardware Discussion
    Last Post: 01-23-2005, 03:43 AM
  4. epia m1000 nehmiah + laptop HD problems
    By chicochu in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:15 PM
  5. PDA and HD solution to play mp3s
    By prado_sergio in forum General Hardware Discussion
    Last Post: 12-30-1999, 01:57 PM
