Results 1 to 4 of 4
Thread: New Setup (Comments / Suggestions Appriciated!)
    Newbie MrLister's Avatar
    Apr 2005
    Vancouver
    Post New Setup (Comments / Suggestions Appriciated!)
    Ok well. I'm a uber noob when it comes to carputers so bear with me. If you have a short temper, please hit the "back" button now and don't waste any more of your time.
    Anyways after days and hours of research I put thogether this system. Let me know if I can improve it (money is not a concern) or any other comments.
    ABIT NF7-S
    AMD MOBILE ATHLON XP-M 3000+
    OPUS 150
    Kingston HyperX 2x512MB DDR400 PC 3200
    NEC Slim DVD/CD Burner
    Mini USB Cam
    USB Cam 2
    PS2 Mini Key
    PowerMate
    DeLorme Earthmate GPS
    Clifford Matrix RSX3.5
    IRMan
    7" Lilliuput
    CREATIVE Sound Blaster Audigy 4 Pro
    Anything I can do to make it better?
    Thanks,
    Milun
    Learning Status: |#####-----| 50%
    System Setup: |----------| 0%
    Apr 2005
    Vancouver
    Variable Bitrate numbers's Avatar
    May 2005
    If you simply must have the onboard video, I'd recommend the Abit NF7-M over the A7N8X-VM. It is worth making the extra room for it in most situations. It may even be worth it to lose the onboard video and go with the NF7-S.
    If cost is truly no matter to you, then the 3000+ is no problem, but you could (read: "I would") go with a 2500+ or 2600+ and be just as well off. They cost less and perform no different. Maybe even better.
    The ram you chose may be too slow for the processor unless you intend to run the fsb at 266. (don't do that unless you have no choice) Then again it may do perfectly fine. I don't know how far that stuff can be pushed. Nice timings, though.
    Apr 2005
    Vancouver
    Not bad. I might do that.
    On newegg.com I found the card http://www.newegg.com/Product/Produc...o.x=16&Go.y=35
    Except what's the difference between a SSP, IGP and Ultra 400?
    Thanks,
    MrLister
  1. My first carputer: Need Suggestions / Comments
    By Underfunded in forum Newbie
    Last Post: 03-14-2005, 10:55 AM
  2. Power setup scenario - Suggestions?
    By Coeus in forum Power Supplies
    Last Post: 01-16-2005, 04:30 PM
  3. Complete the wiring schematic for my car pc. Suggestions? Comments?
    By imprezive one in forum General Hardware Discussion
    Last Post: 01-09-2005, 07:16 PM
  4. 1996 Ford Ranger - Suggestions on Sound Setup
    By Mrbmw99 in forum Car Audio
    Last Post: 11-10-2004, 02:47 PM
  5. Replies: 4
    Last Post: 04-18-2004, 11:50 PM
