Results 1 to 6 of 6
Thread: Carputer won't boot off desktop power supply
    Oct 2004
    So after a few days in the car, I decided to pull my CPU so I could set a bunch of software up from the comfort of my desk.
    I pulled out the integrated Opus 90W, and hooked up the output cables from a Shuttle computer power supply (200W).
    The carputer comes up to the boot screen, beeps, and runs the memory test.
    Then it just hangs.
    Any thoughts? Everything was running great through the Opus in the car, and I believe this is how I had things hooked up way back when I was first setting stuff up...
    TIA
    David
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Did you try taking the cpu back to oyu car.....??
    Low Bitrate Cheech's Avatar
    Mar 2005
    Columbus, OH
    All the cables are plugged in right? 12V processor rail, main power, all that? RAM in tight?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    If you have a PSU that can output 7.5A on the 12V line just use that to power the opus 90 and dont mess with the internal connections.
    Oct 2004
    I thought I read here that that was bad...
    Mar 2004
    Bristol
    nope. if you you will see that is have been recommended as a way to test your setup on your bench. Just use a couple of wires in the ATX connector to tuen on the PSU.
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 11:48 AM
  2. Replies: 6
    Last Post: 03-20-2007, 10:16 PM
  3. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 05:46 AM
  4. Testing a power supply to see if good or dead?
    By Squeezer in forum Power Supplies
    Last Post: 03-17-2002, 12:19 PM
  5. What is the ultimate carputer power supply??
    By THEMP3KID in forum Power Supplies
    Last Post: 02-15-2002, 05:34 AM
