Results 1 to 7 of 7
Thread: USB 3 and 4 on EPIA
    Dec 2004
    BE
    USB 3 and 4 on EPIA
    Were any of you able to connect USB ports 3 and 4 of your EPIA MII mobo's? I connected everything ok but the ports don't work. I first thought it would be a driver problem, but silly me, the ports don't even have power.
    Could it be that if the controller is not installed properly, that the ports don't even get power?
    Could it be that I have to set some jumpers to enable those ports?
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    mine work fine not that it helps your problem any.
    Maximum Bitrate DeltaFX's Avatar
    France
    Via board use a different pinout assign . Check mini-itx.com, they have the via USB header detailled.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Silly question but did you connect the header to some USB connectors?
    Sound Stage
    Eclipse|MTX|Infinity
    Dec 2004
    BE
    Quote Originally Posted by DeltaFX
    Ok, I'll try to see if my connectors use the same schematics as on the mini-itx site. Allthough you would think that they have the right pinouts when you use cables specificly for that purpose.
    Dec 2004
    BE
    Quote Originally Posted by -zip-
    Silly question indeed . Yes I did connect them and the cable is key coded so I couldn't have made a mistake.
    Dec 2004
    BE
    Heyhey I did it. Found out that the wiring of the case wasn't fully plugged in. Redid all the wiring and it works like a charm. Two extra USB ports for free, sweet.
