out of curiosity... how stable is your system? im thinking of switching from a VIA M10K carpc to a athlon xp-m system... any suggestions on cases/power/cpu/mobo's? thanks
Anyone had good luck with a particular hS and fan. I'll be running an AMD XP MObile 2400 (35W) on a Biostar M7NCG-400. I wan't to make sure it adequately cools while keeping loudness and size to a min, thanks.
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Any HSF combo designed for an AthlonXP will work.
Zalman HSFs are big, but designed to be quiet.
Personally, I'm going to use a low-profile cooler like this: http://www.directron.com/cck6012.html
Since the Mobile XP runs cooler, it should work quite nicely, I think.
how about having to hack anything on the motherboard in order for the XP-Mobile cpu to work correctly in a desktop mobo?
i have a similar setup, see my sig. In any case, I'm currently using a Gigabyte cooler (GIGABYTE Neon Cooler 7 GH-ED721-LC). My system is mounted under my chair, and I can't even hear it. Thus far, it's kept my system cool, and the true tests will be coming up here as the temps here in Phoenix approach 110 degrees. So far, so good! It also looks cool with the blue LEDs lol, and only cost $12.50 at newegg.com! Only downside is that it's pretty damn big, barely fits snugly under my seat.
-GiZak-
Carputer Project: 98% Complete!! *tweakin'*
Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
how about rebooting, lockups? did ya have to hack the motherboard to make the mobile cpu work? thanks again![]()
going off topic for chita,
i couldn't get it to work right outta the box, but after some help from somebody else w/the same prob, all that was needed was changing the fsb and multiplier in the bios. (note: you need an overclockable mb to do this). No other "hacking" or wire tricks were needed *thankfully*.
p.s. thus far, I havn't had any reboots or lockups related to cpu compatibility or heat.
-GiZak-
damnnn... how hot has it been getting over there in arizona? my gf is from there and she tells me stories of how FREAKIN hot it gets around there (she is from scottsdale) so your saying all you had to change were 2 bios settings??? then it worked perfectly?how many USB devices are you running? thanks again bud
in the car, it can go past 140 degrees if left outside in the sun lol. I've seen my temp reading get around 120 degrees out by the pool last summer. Currently I barely have my 2200 mobile overclocked a hair, don't remember the settings hehe, but if it gets unstable, I'll underclock it (main reason for getting an oc'able mb).
i have 6-7 usb devices:
bt dongle, multi-card reader, cell phone cable, touchscreen, wireless logitech controller, blue el keyboard, and a usb mouse i sometimes plug in.
-GiZak-
wow... i really gotta stop using that damn VIA M10K.... its in the 80's/90's right now here in southern cali and im getting major rebooting/freezing with my carpc....![]()
