Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Harddrive mounting
    Low Bitrate Stingah's Avatar
    May 2005
    Norway
    Harddrive mounting
    I need some sugestions on how to mount a harddrive in this thread. Pictures of my suggestion is comming right up.
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    There are multiple threads about this...
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    May 2005
    Norway
    could not find a good one.
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    well lets see the pictures...
    rebuilding carpc... kinda..
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    Really doesn't matter. Most people say mount it vertically or sideways just to be sure the read/write heads don't crash during bumps, but I have mine mounted flat and live in upstate NewYork with the WORST roads, never had a problem.
    Basically wherever you have space!
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    2000 Mitsubishi Eclipse GT
    - V6 216hp
    - KYB-AGX adjustable struts
    - Konei Alloy 17" rims + Pirelli P-Zero's
    - AEM slotted brakes
    - AEM CAI
    Apr 2005
    mount it in your radiator, the anti freeze will absorb the bumb and keep it cool!
    May 2005
    Norway
    This is my sollution.. I used some powerful strechers.
    Elsewhere
    Quote Originally Posted by Stingah
    I recommend using the screws that come with the hard drive.
    Seriously, you give us no frame of reference whatsoever. There's far to little information to be able to assist you in your hard drive mounting plight.
    Is your PC in a case or not? Is it in the glove box? Behind the dash? In the trunk? Under a seat?
    Is the hard drive 3.5" or 2.5"? Maybe it's an old 5.25 double-height behemoth?
    Now where is there adequate space for the hard drive?
    You ever wonder why the doctor asks so many damned questions?
    He's gathering information in order to make a proper diagnosis and recommend a workable solution!!!!
    INFORMATION, n00b. It's not just for taking exams.
    Lastly, if you have a solution, why are you asking for other suggestions?
    How about the Wiki?
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    The rule of thumb is to mount with the platters aligned facing the same way as the wheels.
    My HDD is mounted using standard screws, hard against the case.
    I have an expensive suspension system also, it came free with the car.
    Oh, and I'll bet a LOT I have worse roads here in the English countryside than new york.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    May 2005
    Norway
    I'm sorry. I just wanted many suggestions of how to mount the harddrive for other people to see. As you can see I have allready mounted mine, so its no problem for me.
  1. USB harddrive disappeared
    By blak3r in forum General MP3Car Discussion
    Last Post: 04-19-2005, 04:56 AM
  2. Replies: 2
    Last Post: 09-08-2004, 07:07 PM
  3. 5volt line? tap off harddrive/ PS2 /kybd?
    By chuckctv in forum Power Supplies
    Last Post: 08-28-2004, 02:46 PM
  4. Harddrive mounting idea..
    By Custommx3 in forum General Hardware Discussion
    Last Post: 05-25-2004, 12:39 PM
  5. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 06:40 PM
