Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: COOL carputer with AC?
    May 2005
    Exclamation COOL carputer with AC?
    Hi,
    I have been investigating through this forum and cant find any member who is cooling his/her caputer using the AC car system, am I wrong?
    Im from SPain and summer is about to start... and this summer is said to be the hottest summer in 60 years more or less... so i better find a better way of cooling down my carputer.
    So, is there anyone who has done it with positive results?
    Thank you all
    Mar 2001
    What kind of humidity to you have in Spain? If you're in an area where the humidity is high, you should be careful when forcing cold air onto the hot computer compents. Moisture could accumulate, and damange the mainboard, the support components, etc.
    I'd be incredibly impressed to see a water cooled CPU that uses the vehicle's cooling system (antifreeze), pumped through it.
    The hard part is the tubing, the pumps, and running it all back to the trunk. I say trunk, because if you can put it in your dashboard, you're probably running an embedded system and not maxing out an overpowered CPU.
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
    Variable Bitrate numbers's Avatar
    May 2005
    Humidity shouldn't present a problem. The great thing about a/c is that the moisture is removed from the air as it is cooled. If it didn't, you'd have one hell of a time defogging your windshield.
    I have seen designs for a watercooling setup that used a radiator mounted up by the engine radiator. I don't know if it was ever built though.
    FLAC -zip-'s Avatar
    Ontario/Canada
    I cool my lilli with the A/C
    Sound Stage
    Eclipse|MTX|Infinity
    Raw Wave justintime's Avatar
    Apr 2005
    So what do you do in winter? I assume you would have no choice but to pump HEAT to it?!?!
    Quote Originally Posted by -zip-
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Mar 2001
    Not necessarily true. Humidity forms when there is an extreme difference between temperatures and there is moisture in the air. If your carputer is in the trunk, and if it's hot (with high humidity) back there, your carputer could develop moisture.
    Of course, I was assuming that the original poster has a sedan/coupe and not a hatchback.
    Mar 2001
    When you say that, you're assuming a closed environment. If you have your windows/sunroof open in a high humidity environment, your AC isn't going to "remove moisture". In fact, it's going to act as an accumulator and help it develop moisture. Try driving around in the Southeast USA (known for high humidity) with windows down and AC cranking - you'll quickly see water all over your AC vents.
    The same thing would happen to your CPU/Mobo.
    May 2005
    To be honest I'm not entirely sure what you're trying to say. The a/c system removes moisture from the air it cools and that's a fact.
    May 2004
    from what i can remember of my science classes, the accumulation of moisture is going to be dependent on the level of humidity. the difference in temperature will cause water droplets to form, which is related to the humidity level. i live in atlanta (which is pretty hot and humid) and when i blast my a/c during the summer, i don't get any kind of moisture in the car, but i can see water dripping from the exhaust pipe and from underneath the engine compartment (i assume its condensation from the compressor). so the amount of moisture you'll get in the cabin will be dependent on how humid it is in there.
    Maximum Bitrate kirbycope's Avatar
    Apr 2005
    Metro Denver
    The dew point is what your most concerned about. The closer the dew point temp and the actual temp are the more likely moisture is to form, i.e. humidity or the level of moisture in the air. So when its hotter the air contains more moisture and running AC with than amount will be asking to pour water on you compy. Sweat cools your body down and so does cold, denser air with a high dew point as AC run in the summer. I say no AC. Use an independent source, fans are used for their reliability and proven record. Want to get fancy? Use lighted water cooling an put it as a type of display like the car audio guys.
    Post Whore's tip:
    User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
    http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. My first carputer
    By hotwire132002 in forum Show off your project
    Last Post: 11-08-2004, 09:32 PM
  3. Project Car needed some gearheads on Carputer
    By FastAttack in forum Newbie
    Last Post: 11-04-2004, 01:33 AM
  4. Anyone else using del.icio.us for carputer links?
    By revgeorge in forum General MP3Car Discussion
    Last Post: 10-10-2004, 04:58 PM
  5. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
