Results 1 to 5 of 5
Thread: Antenna as actuator?
    Constant Bitrate CA 3000GT's Avatar
    Jan 2003
    Palo Alto, CA
    So, Im in need of a 6" actuator... but they seem a bit hard to come by.. So, what about getting a car power antenna & motor off ebay & clipping it to the length I need.
    will the motor pushing the antenna automatically shutoff when the antenna is fully extended? Or do I need some circuitry to stop sending power to it the second its extnded?
    would that not work? what about the actuator that pushes the headlamps up on those cars with headlights that flip up?
    1995 SL stock
    Working On: GMAT
    Given Up On: Custom motorized lcd
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This is not a bad idea but remember that antennas extend a couple of feet. I think they use a wire inside a hollow metal segmented shaft. The wire is wound onto a spool to retract and unwound to extend. Because the shaft is metal, the wire doesn't kink.
    Do a search for "keyboard extension" or similar terms. There's a guy on here who had the same need and built one out of lego technic parts and a spare motor he had. He's got video of it working. Pretty cool.
    Want to:
    May 2005
    might do the trick if you dont need the full 6". If you do a fulcrum could extend the throw. Danaher Electrak1 12vdc Linear Actuator
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Power antennas work well for motorization but have a few draw backs. They are fast and not powerful. They can be slowed down though. There are two ways to control the antenna ...limit switches or a timer. I prefer limit switches because they are generally easier to adjust. Sometimes there is no room to install the switch and a timer has to be used. Only problem with the timer is getting it timed so the motor does not burn up. Cool thing about power antennas is they are very quiet and small. Motorization is best when the motor is not seen nor the tracks and nothing is heard when it is in motion.
    Fulcrum also work very well. I have used door lock actuators to move plexi doors with a fulcrum. The doors move very fast with the DLA.
    Apr 2005
    lancashire
    all actuators really are, is a motor attached to a threaded rod, this rotates and the moving or extending part runs up and down the threads stopped at either end by limit switches.
    small actuators are available but are expensive, at least in the uk they are. if you really want to buy one, try your local lawnmower repair shop, countax uses one that moves about six inches to lift the cutting deck.
  1. Replies: 7
    Last Post: 03-04-2008, 10:16 PM
  2. Using Radio Antenna for GPS
    By phita23 in forum Newbie
    Last Post: 03-27-2005, 12:42 PM
  3. lengthening fm transmittor antenna wire
    By hand in forum General Hardware Discussion
    Last Post: 03-24-2005, 10:21 PM
  4. 2.4 GHz Mobile Antenex Antenna
    By Mrbmw99 in forum Wireless Communications
    Last Post: 01-18-2005, 12:49 AM
  5. Question Regarding Power Antenna
    By temposs in forum Newbie
    Last Post: 11-13-2004, 07:14 PM
