Results 1 to 6 of 6
Thread: Mobo With On-Board 5.1
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Does anyone know of any mobo with on-board 5.1 surround sound?
    Debating on installing a carpc in my Jeep.....
    Apr 2005
    lancashire
    well the mini-itx epia-m 933 I use has 5.1 , you just use all the audio ports as outlets and set the speakers etc up in control panel/sounds and audio devices.
    I presume all the later, at least, epias are the same.
    Variable Bitrate numbers's Avatar
    May 2005
    Pretty much any good motherboard with onboard sound has 5.1. Well... that may be a slight overstatement, but really it shouldn't be hard to find onboard 5.1 by any means. If you're a serious audiophile though, consider a separate sound card. Onboard still has yet to compare to a quality separate sound card.
    Jul 2004
    Tampa, FL
    alright thanks for the help
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    nVidia boards have great sound from what I hear
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    alot of the newer intel boards ive seen have 5.1 on them in both digital/optical and standard 1/8" out.
    Your everyday carpc geek and tech guru at your service. *bow*
  1. 5.1 info help
    By ummagawd in forum Car Audio
    Last Post: 03-31-2005, 12:30 PM
  2. enabling 5.1 on m10K mobo!??
    By OriginalNick2 in forum General Hardware Discussion
    Last Post: 01-13-2005, 02:49 PM
  3. Asus Micro Mobo and AMD XP-M 45W Barton
    By MatrixPC in forum General Hardware Discussion
    Last Post: 01-05-2005, 05:26 PM
  4. FS: mobo, power supply, CPU etc just look!
    By dannn in forum Classified Archive
    Last Post: 11-01-2004, 09:52 PM
  5. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 08:24 PM
