Results 1 to 9 of 9
Thread: RAM Compatibility Question
    May 2005
    Hi All.
    Just a quick question, is the below RAM compatible with the Epia M10k board?
    I think it is, but just wanted to check before buying.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
    Epia M10k, 1GB RAM, 40GB HDD, 7" Touch, DVD-RW Drive, Bluetooth, GPS, GPRS, all neatly hidden away in my Audi S2
    May 2005
    Derbyshire, UK
    55 for 1 gig....not bad, 512 would be enough though I reckon. Looks to be compatible to me, others will be more knowledgeable though...
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    yeah 1 gig is a bit of overkill
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    it is compactible and no 1 gig is no overkill is play safe.....I had 512mb and changed to 1 gig and the apps for my run better..(think in the time that you estressing the puter loading maps/mp3/voice rec/radar detector and so on............
    As long the mobo support it you can put the gig in good use...
    VIA EPIA M10000 Nehemiah Mini-ITX Motherboard
    System Memory - 1 DDR266 DIMM socket
    - Up to 1GB memory size
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Feb 2000
    AZ
    Computers, towing, and college girls all have one thing in common... too much RAM is never enough.
    99 ram 5.9 turbo
    P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
    Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
    May 2005
    Derbyshire, UK
    Just remember when hibernating it has to write the contents of memory to disk.....and read it back from the disk on startup.
    Dunno how much time it would add, but it must add something ??????
    Old setup
    New setup
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Quote Originally Posted by markbuts3
    If you think about it.... if you are using the extra memory, it will save time. Whatever it caches to virtual memory will take longer to backup and restore than what is stored in RAM. It would be reading and writing from/to the HD, while doing the same from the RAM.
    This is hypothetical, and I am no expert, but I believe it would be better with more ram.
    Carputer status: [-*---------]
    Im thinking laptop...
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    Quote Originally Posted by shizzle
    The thing you are overlooking is that the RAM has to be written out to the HD, and then read back in. Windows doesn't do any optimization on the size of this file, and it writes out a 1GB file if you have 1GB of ram. This reading and writing take up most of the startup/shutdown time when hibernating (the little meter going across the screen).
    Cuttin the ram by 50% wont get you half the boot time, but it will be less.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    May 2005
    I dnt hibernate my PC anyway, it loads up and shuts down for each time the car is switched on and off, Thought this would be the best way to keep the system running at its best, as the longer a system runs, the more bogged down it can become and it boots up in under 60 secs, so its no hardship.
    1GB as i will be using for Sat Nav, MP3 playback, Phoco, sometimes films etc etc More there is there, the less HDD access is required and for the sake of a few quid more than a 512 im gonna chuck in all it can take to maximise performance.
    Thanks for the help guys
  1. REALLLY noobie question on RAM
    By tdevil in forum Newbie
    Last Post: 02-01-2005, 02:45 PM
  2. Ram question
    By EriCCirE in forum General Hardware Discussion
    Last Post: 12-06-2004, 07:35 AM
  3. Replies: 5
    Last Post: 04-18-2004, 12:46 PM
  4. RAM question
    By lummox in forum General Hardware Discussion
    Last Post: 02-11-2004, 05:29 PM
  5. RAM type conflict, easy question, i just dont know!
    By dudah85 in forum General Hardware Discussion
    Last Post: 04-27-2001, 12:19 AM
