Results 1 to 10 of 13
Thread: reverse polarity
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    reverse polarity
    if one had to guess...
    on an a/c adapter or cigarette lighter adapter... the wire coming out being two wires insulated and stuck together, one being striped (marked white)...
    which would you say is positive and negative?
    what would happen if i reversed polarity?
    please help me from blowing stuff up!
    N
    [4Runna]
    next - wifi
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    uhhhh if u still have the cig lighter itself the female part of it - usualy the TIP is the positive and the 2 clips on the sides are the grounding points hope that helps!
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Q.which would you say is positive and negative?
    A.In electrics and electricity they teach you that the live colors are always the positive but i found that in some cars (like mine) the live color (in this case red) is the negative so better get a tester and check polarity.
    Q.what would happen if i reversed polarity?
    A.You blew a fuse.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Dec 2004
    NY
    Quote Originally Posted by thanatos106
    A.You blew a fuse.
    and so i did
    so then tell me this.
    i had it right the first time, it was going to power a usb hub. usb hub works fine powered using wall adapter, but my hard wiring wont work
    when i plug in the hard wired adapter, the computer freaks out saying the usb device is unrecognizable. whattup with that?
    [4Runna]
    next - wifi
    Nov 2004
    So you can now plug the usb hub and it powers on and evething but the computer freaks when plug????
    Try in other usb in the PC (better from the ones behind the mobo no the front panel)
    If that doen't make it work bring it inside and check if it work.
    This sound more like a driver issue.
    Nissan Aux-in MOD
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    A cheap multimeter is an invaluable piece to add to your carputer toolkit. Just drop by Radio Shock and pick one up, you'll be suprised how useful it is.
    Want to:
    FLAC -zip-'s Avatar
    Ontario/Canada
    Or take it to Radio Shack they will test it for you free of charge.
    Sound Stage
    Eclipse|MTX|Infinity
    Nov 2004
    NYC
    It would be a wonderful surprise if the guys at RS knew what a multimeter is.
    Nov 2004
    Yeahhh some call it tester or multimeter so a the end you just point to the shelft and say...."yes tha little yellow box with the 2 cables !!!
    Nissan Aux-in MOD
    Oct 2004
    South Carolina
    what setting do you put a multimeter on to test polarity?
  1. Displaying reverse camera on a carputer?
    By coachreed in forum LCD/Display
    Last Post: 04-22-2008, 05:47 PM
  2. Lilliput Power Polarity?
    By aleromaster in forum LCD/Display
    Last Post: 09-10-2004, 02:22 PM
  3. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:21 PM
  4. Lilliput reverse image?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 01:14 AM
  5. Fried Inverter due to reversing polarity???
    By wonderworm in forum Power Supplies
    Last Post: 03-24-2004, 12:46 PM
