Results 1 to 4 of 4
Thread: Samsung 16GB flash drive
    Constant Bitrate hanzacra's Avatar
    Mar 2004
    Washington, DC
    News: Samsung 16GB flash drive
    News:
    Samsung says it has developed a way to store up to 16GB of data using Flash memory, a development that could lead to extended battery life for notebook and tablet PCs. Flash memory has a power consumption that is five percent of today's hard disk drive, according to the company.
    These solid-state disk (SSD) Flash-based drives will also provide faster access to data, at about two-and-a-half times the speed of current notebook hard drives. In tests, Samsung was able to read data at 57 megabytes per second (MBps) and write at 32MBps.
    Flash drives also offer the benefit of less noise and heat emissions. They are also less temperature- and humidity-sensitive, meaning Flash-based drives can be used in a wider array of applications and environments.
    The disk drive itself will look much like a regular 1.8-inch hard disk drive, meaning manufacturers will have to make minimal adjustments to PC designs in order to incorporate the new drives.
    Samsung expects Flash memory drives to make the move from MP3 players and digital cameras to larger consumer devices as Flash-based drive capacity continues to expand.
    SSD Flash drives based on the new technology are expected on the market by August of this year.
    EPIA M10K, Lilliput 7", 512MB RAM, 40GB 2.5" HD, M1-ATX, RoadRunner, FreeDrive, BU-353 GPS, Sabrent TV Tuner
    Jan 2004
    So when can i get one of these in a Handheld?
    Bruno Speech Recognition - Advanced Speech Recognition designed to control any program. Extra support for FrodoPlayer and Winamp.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    But did they get around the problem where you can only write to the flash so many times (ie a pagefile would ruin it because of repetitive writes)
    Elsewhere
    This was posted not two days ago, complete with links.
    SSDs have been discussed here many times.
    How about the Wiki?
  1. flush mounting slot loading drive
    By residentalien in forum Fabrication
    Last Post: 12-29-2004, 06:50 PM
  2. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 01:50 PM
  3. Need a short dvd drive
    By skippy_geek in forum General Hardware Discussion
    Last Post: 05-12-2004, 06:24 AM
  4. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 12:39 PM
  5. External USB drive
    By mtmsol in forum General Hardware Discussion
    Last Post: 11-27-2001, 06:25 AM
