Results 1 to 10 of 11
Thread: Relay Wiring
    May 2005
    Relay Wiring
    The pic below tells me that 30 and 87 is the wire I want to control. So if I cut into my 12 volt line to my back up cam, I would normally put a switch there, but I need to put a relay there. So if I attach those two ends to 30 and 87, I put the two poles of the switch on the other two posts 85 and 86?
    [IMG]three relays.jpg[/IMG]
    A pic is worth a thousand words.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Yep.
    And don't forget a diode across 85/87.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Mar 2004
    London, UK
    Quote Originally Posted by PatO
    Yep.
    No. If you put the two poles of the switch across 85/86 then that will achieve nothing.
    One of the coil connections should go to ground. The other should connect to one connection of the switch. The other connection on the switch should connect to a 12v source.
    And the diode goes across 85/86. Make sure the stripped end of the diode is connected to whichever coil connection is connected to the switch.
    Rob.
    May 2005
    Thanks for answering Rob. I drew the pic just the way you described it, but it seems to me that connecting a switch directly to a 12 volt source is defeating the whole purpose of the relay. I must be missing something.
    If this pic is right, what do I do with 30 and 87? I'll worry about the diode after I understand this wiring.
    [IMG]relay wire1.jpg[/IMG]
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Have the cam's red lead go into 87, then attach 30 to a positive power source.
    If youre switch is big enough, why not just put that on the power line? like, a normal switch?
    May 2005
    Thanks for the replay Kyle, the switch is very small, I want to build it into the steering wheel. I still don't understand how I can hook that switch up directly to the 12 volt source when it's so small.
    Mar 2004
    London, UK
    Quote Originally Posted by Vee24
    Relays are usually used when the current needed is higher than the switch's rating or the control line's output capability.
    Check the current rating of the switch and the current consumption of the cam and if the consumption of the the cam is less than the rating of the switch then you can just use the switch in line as you originally wanted to do.
    Rob.
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Do it the easy way:
    May 2005
    Thanks Hombre, that makes sense. With this setup, do I need a diode?
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by gommino
    Doh!
    Sorry about that...
  1. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  2. relay wiring
    By nsmoller in forum General Hardware Discussion
    Last Post: 03-28-2005, 11:31 PM
  3. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 08:55 PM
  4. Wiring help, possibly a relay?
    By Ninety8NeonACR in forum Hardware Development
    Last Post: 01-26-2005, 09:57 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
