Results 1 to 10 of 10
Thread: Errrrrrrr.....a lil help
    Jan 2005
    Melbourne - Australia
    Hey,
    I was wiring up my LCD character display last night, and in the guide i was using it says for the register select LCD pin i need to use the wire coming from the parallel printer port pin 16....there aint no wire on pin 16.....so i was wondering if anyone knew wtf i should do.....
    catch
    btw..lcd from www.jaycar.com.au
    found printer cable lying around...
    Newbie volvo9's Avatar
    Apr 2003
    North Attleboro, MA
    Have a little more info? What schematic are you using to wire up the display?
    Is the display HD44780 compatible?
    I wired up one before, but I didn't run into such troubles, the parallel port has 25 pins, so why are you saying you don't have a pin 16? does the cable not have it?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    ditch the printer cable, get a actual DB25 connector. the register select pin is going to be needed.
    肚子笑痛了
    S60 Install
    Jan 2005
    Yeah the cable has no pin16...im like wtf...could any other wire on a different pin do the same thing?
    will trial and error work? or will that screw the display??
    i was using this guide http://www.overclockers.com.au/techstuff/a_diy_lcd/
    and yeah as far as i know its HD44780 compatible.
    thanks
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    oh - be careful - some of those lcds - the contrast is between -5v and 0, NOT 0 and +5v. I have killed one doing that.
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
    May 2003
    Miami, FL
    Quote Originally Posted by oliffied
    thanks
    yeah, to keep things safe, I would really just take the time to find the proper connector, i've wasted countless hours fussing around with printer cables for LCD's when in the end I usually end up getting the right connector or blowing out my LCD.
    肚子笑痛了
    S60 Install
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    RatShack used to have straight DB25 connectors that had all the pins. Sometimes they'll make cables without all the pins as cost-savings.
    Aug 2003
    or jst make your own. Go and get a 16 or 25 pin data cable and the male DB25 connector. and enjoy soldering 25 pins
    If you use a 25pin cable- get the 14odd data pins all wired - then split the remaining wires into +5v and gnd. I figured that between them - they should be able to carry the current to run the lcd. i think i had 5or so for each rail. that means theres only one cable to run - and the molex connecter just comes from the DB25 connecter on the computer end
    i did that coz i needed a really long printercable. (Under seat -> dash)
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    Creative IR Remote
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Aug 2003
    also - make sure you use a detachable connecter at the LCD end. YOU WILL REGRET IT IF YOU DONT!
    i did - and half my tracks lifted. so i have some dodgy soldering - but it works.
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    Creative IR Remote
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Jan 2005
    awesome cheers fellaz
  1. I hate lil' kids w/ brand new cars
    By migel628 in forum Off Topic
    Last Post: 06-20-2009, 11:49 PM
  2. Replies: 6
    Last Post: 05-21-2004, 10:47 PM
  3. Finally got a lil site going...
    By PoBoy in forum General MP3Car Discussion
    Last Post: 08-30-2001, 03:12 AM
