Results 1 to 8 of 8
Thread: stupid relay question please help
    May 2004
    ok ive searched all over for this answer and i think i already know it but i just wanna make sure. everyone knows that when you connect the positive lead of a battery to the negative or ground it shorts the battery and that's bad. well when using a relay, if you run a wire from the + terminal to the coil of the relay, and then just ground it doesn't that short it out? in every post ive seen this is what people do. it just seems to me this would short out the battery unless the relay coil had some sort of resistance or votage usage. will someone please explain this to me. any help is appreciated. thanks.
    Variable Bitrate numbers's Avatar
    May 2005
    The relay coil does have resistance. Look at the specs for your relay and it will say that is uses something like 50ma at 12v.
    May 2004
    so you can run it straight out of the battery and right back in without worrying about shorting it?
    here are the specs for the one i am using. http://support.radioshack.com/suppor...oc38/38002.htm
    May 2005
    Yeah you can.
    Newbie Cocoman's Avatar
    Feb 2005
    Canada
    By that logic even light bulbs would cause short circuits since they are also coils and involve connecting +ve to -ve. Obviously this is not a problem because they do not blow fuses in your house everytime they are turned on. As numbers mentioned, it does have some resistance so its not the same as hooking up the the +ve lead to the -ve lead directly.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    be careful though. Make sure you run the wires to the coil and not the Normally Closed contacts, or you will see sparks fly. But a fuse inline just in case like always
    May 2004
    where should i put the fuse? before the coil or before the switching side?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Put it between the +12 and the coil. Before the coil.
    Want to:
  1. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  2. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
  3. 12V relay + diode question
    By cybermob2 in forum Power Supplies
    Last Post: 05-18-2004, 01:11 PM
  4. Relay question
    By lopan in forum Power Supplies
    Last Post: 02-25-2004, 10:17 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
