Results 1 to 10 of 11
Thread: Are two c: drives possible?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Home computer has C: and D:
    Carputer has C:
    O/S is XP Pro
    I want to bring the hard drive in the house that is being used in the carputer, hook it up to my home computer and copy the info from my home computer to the carputer.
    But they both have drive's C:
    I have about 2 gigs of data to transfer, I could go wireless but its kinda slow and does not always transfer well. No CD/DVD in the car yet.
    Is this possible?
    Sound Stage
    Eclipse|MTX|Infinity
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    i've never had a problem bringing in the hard drive. i think it sees it as the F drive. (D and E are dvd drives). i could be wrong though.
    rebuilding carpc... kinda..
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    if you take the c drive out of one pc and put it in another, it will change the drive letter automatically based on what drives you currently have. for example, i can take the c drive out of the computer i have running upstairs and hook it up to this one. since i already have an a, b, c, d, e, and g drives, more than likely, the c drive from the other computer would take the f drive letter or the h drive letter.
    Your everyday carpc geek and tech guru at your service. *bow*
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    If you use the IDE cable that is inside you home pc just chang the jumper of the carpc HD to slave...If using USB mod cable or enclosure it changed automatically
    Jan 2005
    Warren, Ohio, USA
    that too. make sure the jumper is set right.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    or just buy a small 10 gig laptop hard drive and a usb enclosure and you can use it to transfer all ur data all the time
    Nov 2004
    If you going to buy a laptop HD get 20 or 40g 'cause can help you better in the future than 10g or go with the KOSUMI minidrive 2g USb compactible for $70 bucks...
    Elsewhere
    Quote Originally Posted by -zip-
    Carputer has C:
    O/S is XP Pro
    Is this possible?
    The second drive will not be recognized as C:. It will be assigned another drive letter by Windows. You'll be able to see all the files & the entire directory structure.
    I do this all the time for clients that have a computer take a **** on them.
    How about the Wiki?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks guys for all the help
    Sound Stage
    Dec 2004
    Miami, FL
    It's worth mentioning that any internal program references wont change. That is, if you're running something on the drive that used to be c:, but now in the new machine is d:, it may not be able to find files.
    For the most part, I dont think this will be a problem for major programs to be able to run, but shortcuts and the like wont work.
    Not a major problem, but worth noting.
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  1. Solid State Hard Drives
    By neon_eddy in forum Hardware Development
    Last Post: 04-12-2005, 01:02 AM
  2. Multiple CD/DVD drives ??? << Newbie!!
    By dashusa.com in forum Media Engine
    Last Post: 01-07-2005, 12:27 PM
  3. FS: 704MB IDE Solid State Drives
    By dj2fast in forum Classified Archive
    Last Post: 05-09-2004, 04:19 PM
  4. Laptop hard drives
    By djmickyg in forum General Hardware Discussion
    Last Post: 04-19-2004, 12:57 AM
  5. For Truck PC: Use 2 old hard drives or 1 new one?
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 11-11-2002, 10:26 PM
