Does anyone happen to know the specs for the CPU fan on the MII 12000 motherboards?
Since I am mounting mine behind the LCD in-dash, i'd like to replace it with a quieter fan supplying the same CFM. I do know the stock 40mm fan is 22dB loud, and I have seen 40mm fans as quiet as 14dB. Anyone know?
EDIT: nevermind, i found the info, it's a 12v Bi-Sonic BS401012M, max airflow of 6.48CFM, noise level of 24.5 dB, and with a speed of 5000 RPM. has anyone seen a better (quieter) fan w/ the same specs?
