Results 1 to 8 of 8
Thread: Overheating or Corrupt install?
    Constant Bitrate naveedh's Avatar
    Oct 2004
    well guys today in the uk west mids, the temp was above then normal. Also the carputer is in the boot and it produced more BSOD's then normal. So was this a heat problem or just a corrupt install. I have had BSOD loads of times so today i removed the cover of the carputer and left a naked board and fan and look, it worked 100% only turned off once probaly because of Low voltage. So is this a heat problem or corrupt install or am i making wrong assumptions?
    Raw Wave
    Jun 2004
    On the beach
    Sorry to thread hijack but I was a little concerned about the temp on my screen today, had to drive round with the sunroof shut :-( to stop the sun going on it.
    The crashes you are getting could be related to heat, does it seem ok when the system is cold??
    Oct 2004
    yea its fine once i leave the case off, also regarding lilliput ,xenarc etc. My lilliput wire literally started burning. Right after the ciggarette light plug and before the egg the wire plastic burnt and 2" of wire is now naked. It just smoked out of the blue? So tomorrow im wiring up to my opus, not safe at all to that egg or through dirty cig lighter power.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    check yer RAM
    www.memtest86.com
    Sometimes issues that appear to be heat related are memory related. I learned that the hard way, after spending $300 to fix a "heat problem" that ended up being a $25 stick of RAM.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Oct 2004
    k thanks, ill check ram, for some reason i thought it was ram before but got convinced that it was heat.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    No harm in adding a fan or venting air in from the cabin.
    TruckinMP3
    Read the FAQ!
    Jun 2000
    Nashville
    Quote Originally Posted by TruckinMP3
    unless you're an idiot like me and spend a wad of cash and lots of time to do that, only to find out that it's a $25 stick of ram that was causing the problem in the first place
    I'M DEBT FREE!!
    Jun 2002
    Colorado
    I would recommend the cheapest solution first.... I have several fans laying arround. If that fixes it then spend the $ on the low noise fan.
    TruckinMP3
    Read the FAQ!
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
