Results 1 to 10 of 12
Thread: laptop cd to laptop hdd adapeter
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    I need an adapter that will plug into the tiny laptop cd plugs but then convert to 2.5" ide, all the ones I find go to 3.5" ide. I want to keep it nice and small, anyone seen one of these.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    you talking about this:
    Nov 2004
    another pic:
    May 2002
    Ohio
    That cd rom connector but adapting to a 2.5" ide instead of 3.5" ide. I did search, all I have found is to 3.5" IDE.
    Newbie techboj's Avatar
    May 2005
    British Columbia, Canada
    I'm not sure if you want to connect a laptop cd drive to a full sized IDE or a cable for a 2.5-2.5. Either way, take a look at the links below:
    http://www.tigerdirect.com/applicati...44974&CatId=81
    or
    http://www.cablesonline.net/2544pinidela.html
    Hope these help.
    Carputer revision !! (arghh - getting costlier than originally expected )
    Vehicle 1: P4-2.4/PM800-M2/512MB/160GB/WLan/dual battery/Xantrex400/700IDT
    Vehicle 2: AMD-XP2500/A7V400 MX/512/120GB//WLan/Xantrex400/700TS
    May 2002
    Ohio
    I need an adapter like the first pic in the thread with the tiny about 1" wide cd-rom drive connector but to a 2.5" ide instead of a 3.5" ide cable. I have 2.5" to 3.5" adapters but they go the wrong way and I'd like to find what I need in one piece.
    Remember when early laptop cd-rom drives used the same 2.5" ide as laptop hdd's and now the new laptop cd-rom drives are the real tiny connector? I need to put a new tiny connector drive in a laptop that used the older 2.5" ide so I don't have space to use the mini cd connector to 3.5" ide then adapt down to the 2.5" ide.
    May 2002
    Ohio
    No one knows of any?
    Aug 1999
    Washington D.C.
    Mar 2002
    50 pin JAE (back of slim CD-ROM) to 44 pin 2mm pitch IDC (laptop IDE) adapter:
    http://216.36.236.148/Merchant2/merc...gory_Code=MPS2
    Nov 2004
    He said that he only want to have one adapter (global) due to space......
  1. Question about laptop HDDs
    By GTPmp3PC in forum General Hardware Discussion
    Last Post: 12-29-2002, 03:14 AM
  2. good laptop cd rom ?
    By oddcomp in forum General Hardware Discussion
    Last Post: 11-14-2002, 02:54 PM
  3. laptop cd drive
    By smashr2k in forum Classified Archive
    Last Post: 10-02-2002, 11:42 PM
  4. UK Laptop hdd prices
    By Reaper in forum General Hardware Discussion
    Last Post: 06-24-2002, 04:40 PM
  5. help w/ laptop hdd!!!!
    By aye in forum General Hardware Discussion
    Last Post: 06-06-2000, 09:17 PM
